anyone lower a CGT ?
Old Dec 25, 2008 | 11:44 AM
DNugget991GT3's Avatar
just curious if anyone lowered a CGT ?
i would love to know how the car looks about 3/4" lower
and i wonder if it would improve the handling ?
Old Dec 25, 2008 | 02:41 PM
netburner's Avatar
netburner is infamous around these partsnetburner is infamous around these parts
Only thing you would improve are scratches in the frontlip and the floor panel. A friend of me had the problem last summer, when he arrived at roadworks in the middle of Munich. The car was to low (works height) to get it down the edge which was there, because they removed the upper level of the street. He had to backup, which ended in the mid of chaos for nearly complete downtown Munich. At works standard you have to plan routes with as less problem roads as possible so you can imagine what you have to do after you lower that down.
Old Dec 25, 2008 | 04:45 PM
Jgalt's Avatar
Jgalt is infamous around these partsJgalt is infamous around these parts
Lower?
The first CGT I saw was in Carmel, Ca. The guy had to park it on the street because it couldn't make the decline in to the garage.
Old Dec 26, 2008 | 02:04 AM
ExclusiveTT's Avatar
ExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond repute
doesnt the cgt come with height adjustable stock suspension like the gt2?
Old Dec 26, 2008 | 06:01 AM
03-turbo911's Avatar
Senior Member
Neither the CGT nor the GT2 have an in-car adjustable height control. It can be installed aftermarket though.
Old Dec 26, 2008 | 06:18 AM
Duff Man's Avatar
Duff Man is infamous around these parts
RUF offers it for CGT and GT2. Its a kind of air-hydraulic you can compare it with the system from Lamborghini for the Murcielago.
Old Dec 26, 2008 | 11:03 AM
Khalid I never mentioned "in-car" adjustability - i was talkign about adjusting the collars on the stock suspension to alter the height. I would assume that if porsche put adjsutable suspension on the gt2, they would have put an adjustable system on the CGT since it is double the price.
Old Dec 26, 2008 | 11:22 AM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
there is a kit from porsche to raise the ride height of the cgt. Basically longer pushrods for the dampers and changing the spring preload.
Old Dec 26, 2008 | 11:50 AM
Senior Member
I should never post without drinking a cup of coffee first thing in the morning. Apologies for the misunderstanding!
Old Dec 26, 2008 | 12:37 PM
are you guys saying the cgt doesnt have heigh adjustable suspension ?
Old Dec 27, 2008 | 01:48 PM
mousecatcher's Avatar
mousecatcher is just really nicemousecatcher is just really nicemousecatcher is just really nicemousecatcher is just really nicemousecatcher is just really nice
ride height is adjustable
Old Dec 27, 2008 | 03:44 PM
thats wierd
why would porsche offer a kit to raise the car 20mm, when it has ride heigh adjustability ???
makes no sense
Old Dec 28, 2008 | 06:21 AM
neilwight's Avatar
neilwight is infamous around these parts
im guessing its because like the gt3 etc, the ride height adjustability is there to allow exact corner balancing and not intended to be used to noticeably change the cars overall height in any direction. theres upper and lower limits specified for each corner which allow balancing to take place and keep the car within height specs.
in order to change the height then adjustment of the suspension components would generally be a requirement hence the kit on offer
Old Dec 29, 2008 | 08:42 PM
AutoTalent2's Avatar
AutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to allAutoTalent2 is a name known to all
To answer the original questions, yes people have adjusted the height of their CGT to go lower.
From the factory, the CGT does not come with hydraulic lift suspension like Lamborghini late model cars. However, the CGT does have adjustable coilover suspension which would allow raising or lowering the height of the car if necessary.
KW offers a hydraulic lift suspension solution for the CGT(aftermarket).
Old Dec 30, 2008 | 12:26 AM
ZAMIRZ's Avatar
ZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud ofZAMIRZ has much to be proud of
Originally Posted by STEVE KOJASEVIC
thats wierd
makes no sense
It's not weird at all. You are hung up on "how the car looks about 3/4 lower", that's why it makes no sense.
If you jack the suspension up or slam it all the way to the ground without the proper parts and ignore the factory recommendations, the handling of the car will be severely compromised since you're placing the damper outside its proper operating range and pushing the control-arm beyond its effective geometry.
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
Stuart@VelocityAP
Sep 23, 2015 05:30 PM
