B16 Damptronic
Old May 9, 2009 | 02:33 PM
Z06's Avatar
Z06
Z06 is infamous around these parts
B16 Damptronic
I find the stock 7GT2 to lack shock rebound for a high speed track such as Mosport.
The B16 is the only shock that will work on a 7GT2, using Motons or JRZ will cause computer problems.
Has anyone tried this shock system?
Any info would be great, thanks.
Old May 9, 2009 | 05:22 PM
sharkster's Avatar
You can actually still use a Moton/JRZ set up if you go to a Porsche dealer and have the PASM recalibrated with a PIWIS. It's a pretty simple process and that way you could probably get a much more robust set up than a B16.
Old May 9, 2009 | 05:30 PM
Z06's Avatar
Z06
I was told by a Euro tuner that the 7GT2 is the only car that did not work with the PASM turned off.
There are other chassis sensors that will cause problems with the TC thus cutting power.
I want to go with the Motons or JRZ's but do not want to lose the TC and SC.
Old May 10, 2009 | 10:46 PM
Z06's Avatar
Z06
One thing I noticed is the price of the B16 Damptronic is lower in NA then if you buy it in Europe or a direct supplier such as FVD.
Does this mean it's different spec part?
The only difference in the part number is the NA unit has HO on the end of it.
GA5-E548-HO
GA5-E548
Josh/AWE
Oct 23, 2015 04:33 PM
Josh/AWE
991 Vendor Classifieds
Oct 16, 2015 03:31 PM
RajuPatel
New Member Introductions
Oct 2, 2015 03:28 PM
nagual911
Oct 1, 2015 01:52 AM
Zero911
Sep 24, 2015 06:33 PM
