GT3 exhaust plug help
Old Jun 28, 2009 | 01:16 AM
DrPeter's Avatar
DrPeter has a spectacular aura aboutDrPeter has a spectacular aura aboutDrPeter has a spectacular aura about
Earlier this week I had a car detail where they wiped the interior engine compartment, after this I noticed the exhaust was running load as it would if the exhaust plug mod were done. I have looked to see if the plug is in place and it appears to be. Never having looked too closely before at the passenger side of the engine compartment, I noticed the grey box where the plug attaches to the side of has a 3/4" open steel tube facing downward, beneith it. The tube looks like it should have a hose connected to it but I see no evidence of a hose.
Am I missing a hose? Any other ideas? First pic is for perspective:
Close up of the red diagrammed box above, just behind the two radiator hoses is a rectangular grey solenoid box where the electrical exhaust switch plugs into the side and 2 rubber hoses plugs into above, note the steel nub at the bottom (below the arrow), is that an air intake or is a nubb missing a hose?
BTW, it is a MY07 GT3 with Cargraphic 5 exhaust, if anyone has an other ideas.....
Old Jun 28, 2009 | 03:18 PM
DrPeter's Avatar
Come on guys, someone look into their engine compartment and let me know it they see the same thing. Trying to avoid a trip to the dealer....
Old Jun 28, 2009 | 03:41 PM
Teddy's Avatar
Teddy is infamous around these parts
Just looked at mine ( '08) and it looks the same as yours. The small silver fitting at the bottom of the plastic box does NOT have a hose or anything connected to it.
Hope that helps.
Teddy
Old Jun 28, 2009 | 05:44 PM
gweedo911's Avatar
gweedo911 is infamous around these parts
Mine also looks the same........
Old Jun 28, 2009 | 08:26 PM
DrPeter's Avatar
thanks, I guess its more than a hose. Anyone know if there is a fuse for the exhaust flappers? There is not one labeled in the footwell fuse box labeling sheet that could see.
Old Jul 3, 2009 | 08:43 PM
ze_shark's Avatar
ze_shark is just really niceze_shark is just really niceze_shark is just really niceze_shark is just really niceze_shark is just really nice
Mine neither, nothing connected to that port.
Instead of keeping both valves open by disconnecting the solenoid, try disconnecting just one valve by disconnecting the vacuum line and shutting it closed. Takes five minutes and the result sounds much better in my opinion between 2 & 3K.
Old Jul 11, 2009 | 10:41 PM
an_engnr's Avatar
an_engnr is infamous around these parts
disconnecting vacuum lines
ze_shark,
Can you post pictures or exactly what you are describing? I also would like to have the 1st valve stay open all the time (w/o depending on the sport button), but find having both open at low RPM to cause a bit too much drone.
Thanks!
-DS
Old Jul 14, 2009 | 12:47 AM
DrPeter's Avatar
I think zeshark means disconnect one of the hoses in the solenoid picture above and then cap the holes it creates by disconnecting them.
Originally Posted by an_engnr
ze_shark,
Thanks!
-DS
Old Jul 14, 2009 | 06:19 AM
an_engnr's Avatar
Thanks Dr. Peter -- any idea which hose goes to which solenoid?
And what are you using to cap the two open ends? Is there a specific vacuum line plug, and if so, do you know what size is required?
Thanks!
Old Jul 15, 2009 | 09:03 AM
ze_shark's Avatar
ze_shark,
Thanks!
-DS
Picture here. That's what I called the half/half solution. I think you will be pleased about the result. No drone but more character than stock without getting outrageous. Still advised to run sport mode all the time.
audipwr1
Sep 25, 2021 01:31 PM
alevine
Nov 4, 2015 10:05 AM
JMon
Aug 21, 2015 08:20 AM
TrackOne
Aug 20, 2015 12:56 PM
Vrseis
Aug 20, 2015 07:41 AM
