New Product - GT3 Rear Brake Cooling Ducts
Old Jul 17, 2009 | 01:45 PM
SuncoastParts's Avatar
SuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond reputeSuncoastParts has a reputation beyond repute
A new item for the 2007-08 GT3 & GT3 RS models. This is the same set which comes on the 2010 GT3, and we just installed them on a 2007 GT3. They are a direct fit, some minor triming of the brake shield is required.
They pull air from the underside of the car, and channel it to the rear brake system. This results in lower brake temperatures leading to greater braking performance under high loads, as well as reduced wear.
Please contact me if you have any questions.
SuncoastParts.com
Your #1 Source for Genuine Porsche Parts and Accessories on the Web!
Visit us at http://www.SuncoastParts.com
Call us at: 877-923-1700
Email us at: Parts@SuncoastParts.com
Follow us to stay connected:
Join Our Newsletter | Facebook
Old Jul 17, 2009 | 02:06 PM
NorthVan's Avatar
Ric, will these work on my 06 C2S?
Old Jul 17, 2009 | 02:21 PM
We tested these on C2's and C4's, and Turbo, and the stabilizer drop-links made it impossible to install. So I know it fits 997 GT3's, it may fit a 997 GT2 (we will try to test it, we need a test mule).
SuncoastParts.com
Old Jul 18, 2009 | 05:51 PM
sheim911rs's Avatar
sheim911rs has a spectacular aura aboutsheim911rs has a spectacular aura aboutsheim911rs has a spectacular aura about
What do they cost?
Old Jul 18, 2009 | 07:20 PM
NorthVan's Avatar
Another reason to buy a GT3!
Thanks for the reaponse.
Old Jul 18, 2009 | 10:50 PM
mobonic's Avatar
mobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud of
what option do 997 non gt3 cars have?
old GT2 brake coolers?
Old Jul 18, 2009 | 10:52 PM
rotary rocket's Avatar
rotary rocket has a spectacular aura aboutrotary rocket has a spectacular aura about
Will it fit on a 996?
Old Jul 19, 2009 | 05:25 PM
toadinlaw's Avatar
toadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud oftoadinlaw has much to be proud of
Does it pull the air out of the current vent that is uses to feed the current cooling guide? if not, what will happen when it rains?
Is the price on your web for one or for the set of two? Do you have in stock?
Old Jul 20, 2009 | 06:21 AM
Click HERE for pricing and more info.
This won't fit a 996 to my knowledge, we will try to test it on a 996 GT3. Currently there are none on the GT3, so this is a significant addition. The price on the website is for both sides, including the mounting bracket and bolts.
Not sure about standard 997's, the GT2 ducts may be an option, but they aren't nearly as effective as these monsters.
SuncoastParts.com
Old Aug 23, 2009 | 05:23 PM
sheim911rs's Avatar
I received my ducts but the top portion seems too tight to fit over the lower control arm. I broke one and can't get the other to come into contact with the duct portion....it will break if I try to tighten the screws. Any suggestions would be greatly appreciated.
Old Aug 23, 2009 | 05:42 PM
Steve W's Avatar
Steve W is a jewel in the roughSteve W is a jewel in the roughSteve W is a jewel in the rough
They are a perfect fit on mine and no filament or install issues. But the shields do need to be trimmed. Did you maybe mix up the left and right top clamp portions?
Old Aug 23, 2009 | 05:47 PM
sheim911rs's Avatar
I thought of the right/left issue, but the top part says right or left and the bottom is obvious. For mine, the top just won't fit around the suspension arm. When I do get it over the arm it's overstretched to the point that the tabs won't fit into the brake duct portion. I've tried moving it inboard/outboard a bit without success. ??????
Old Aug 23, 2009 | 06:05 PM
jstrat85's Avatar
jstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to alljstrat85 is a name known to all
not bad!
Old Aug 23, 2009 | 06:11 PM
Steve W's Avatar
There are two little 'teeth' on the top side of each edge of the lower control arm. The top section should mount on the outboard side of these teeth, against it. Is that how you mounted it? You'll also have to have the three 'fingers' inserted into the duct while clasping the top portion over the control arm, or you won't be able to attach the fingers into it afterwards.
Old Aug 23, 2009 | 07:35 PM
sasportas's Avatar
Awaiting Email Confirmation
sasportas has a spectacular aura aboutsasportas has a spectacular aura about
rear cooling duct brackets
I initially broke the brackets when installing the rear cooling ducts. Then I remembered that I had changed the rear lower control arms. They are slightly wider. In order to install, you have to shave off the plastic "ribs" that are present on the internal aspect of the plastic brackets. Once this is done, the brackets fit well.
