RSS Suspension Track Components Installed on a 997 GT2 @ SharkWerks
We've been using the RSS suspension parts for a while now on our cars this White 997GT2 also came in for a dose of suspension work, including our full track-orientated suspension components. The first step was to turn the camber plates to get more camber (an old trick from the 996 days):
Next the bushings are pressed out/removed:
And the RSS monoballs kit gets installed in their place. This kit replaces the four pivot bushings (one per corner) on the inner side of the lower control arms with steel monoballs, increasing the precision of the pivot motion of the control arm as it travels up and down under cornering.
And in go the adjustable thrust-arm bushings. The aluminum adjustable thrust arm bushings replace the neoprene factory units on the other end (outside) of the control arms. This allows for adjustable caster.
And on go the dog-bones. This kit replaces the four upper links (two per side) on the rear end of all 996/997 models. The RSS kit allows for sufficient adjustable camber on lowered cars (the factory adjustment is insufficient on lowered cars, resulting in improper camber settings). The links also replace the neoprene bushings with steel monoballs, reducing movement in suspension components and increasing road feedback and "feel".:
On goes the adjustable toe-steer kit. On lowered Porsches with a factory toe steer link, the limited adjustment results in incorrect toe geometry in the rear. This kit is designed to fix that problem. It also replaces the inner neoprene bushing with a steel monoball.
With a full race alignment by our friends at TC Design this car is fully ready for some track-action...
Here's the project page: http://sharkwerks.com/porsche/997-tu...-upgrades.html
hi there. i have 06 c2s and wanted to ask one thing about suspension.
what can i get done to make it more focused on cornering and overall better to drive fast.? with out spending crazy money. i have now H&R lowering springs only.
im little of topic but i think all the suspension junkies
will be here reading this post!!
thanks alot
will be here reading this post!!thanks alot
Did you guys bulk up the sways? Also, any chance of Motons in that GT2's future? Makes a huge difference.
thanks alot
Thanks guys!
thanks laguna dude. lots of great stuff!! i do mostly just street driving, track in the future. you guys know good place in atlanta area for porsche mods? or should i do it in florida? best place in florida, any tips?
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 18, 2015 03:41 PM
PelicanParts.com
997 Vendor Classifieds
Aug 18, 2015 03:39 PM
