05 GT3: Oil Pressure Warning
Old Nov 19, 2009 | 09:16 AM
Adrift's Avatar
Who let the dogs out...
Adrift is infamous around these parts
My oil level is rock steady, but for the past year, every month or so my oil pressure gauge drops to zero, and I get the warning beep and the light comes on, always for about 2 seconds, and then it recovers and looks normal.
Pressure monitor or switch problems somewhere? Anyone seen this? I have dismissed it since it recovers immediately and my oil level is fine. Could there really be something wrong?
Old Nov 19, 2009 | 10:06 AM
hesperus's Avatar
hesperus is just really nicehesperus is just really nicehesperus is just really nicehesperus is just really nicehesperus is just really nice
got this with our old 996TT; exact same symptoms.
it only happened a couple times, but then went away...
no idea what it was...
Old Nov 19, 2009 | 10:32 AM
wapita's Avatar
wapita is a jewel in the roughwapita is a jewel in the roughwapita is a jewel in the rough
Had the same problem on my gt3. Replacing the oil pressure sensor fixed it.
Old Nov 19, 2009 | 11:07 AM
Adrift's Avatar
Good, that is what I was hoping! Something a shade tree mechanic can do? Any instructions out there?
Old Nov 19, 2009 | 11:17 AM
D-UberCars's Avatar
D-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud of
Same thing happened to my 04 GT3. It was under warranty at the time and they replaced the sending unit.
Old Nov 19, 2009 | 11:01 PM
wapita's Avatar
No idea. I didn't do the work myself.
Old Jun 8, 2010 | 12:08 PM
joel1952's Avatar
joel1952 is infamous around these parts
Mine was replace under warranty. Service tech said it was difficult to reach.
A short time later I got the same symptoms, so I wonder if it is not a sensor problem. Maybe the ECU(??)
Old Jun 13, 2010 | 05:27 AM
rkirshner's Avatar
rkirshner is infamous around these parts
i have the same thing going on rigth now and i am trying to figure it out . in addition to the the pressure gauge falling to zero and the warning message coming on my outside temp probe will also fail . interestingly i find that if i push the cruise control button to turn cc on it fixes the problem . i think it is more thasn some sender unit .
Old Jun 14, 2010 | 10:13 AM
joel1952's Avatar
is it the ecu or the oil pressure sensor??
Intermittent problems are difficult.
I want to wire a gauge, in parallel, from the cabin to the sensor. if that gauge contradicts the dash readout, I would know if the sensor or the ecu are defective.
Old Jun 14, 2010 | 12:35 PM
80shilling's Avatar
80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !
It happens to me on REALLY bumpy roads in exactly the same places every time if I am going faster than a certain speed and hit that patch of bumps... No ACTUAL problems or issues, I think it's just something these Cars occasionally do. As soon as I dialed back my compression damping and softened the Car up, ZERO problems and it doesn't happen. I frimed my shocks back up for a track day, drove that piece of road again and BINGO! exact same issue... backed them off and it was gone.
carsnob
Sep 8, 2015 04:10 PM
ECS Tuning - VW
Sep 8, 2015 01:34 PM
mjdVantage
Sep 5, 2015 07:22 PM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
