More performance for GT3 996 and soon for 997GT3
Old Jan 9, 2010 | 07:34 PM
IMA Motorsport's Avatar
IMA Motorsport is infamous around these partsIMA Motorsport is infamous around these parts
Mike and k24madness
Thanks for the comments and particularly in agreeing that it can be done and that it works like a charm. The observations Mike are great and will pay attention to those bends. I have been considering the air cooled turbos but to be honest i have not water cooled this yet and I have had no failures yet and I have been using these turbos for quite a few years and not cooled them. What has your experience been in the past. We are using the factory ECU for management.
Respectfully
Old Jan 9, 2010 | 10:56 PM
K24madness's Avatar
K24madness is infamous around these parts
Originally Posted by Mike@AwdMotorsports
Some advice maybe to use the New Billet Air cooled lineup to simplify system without water to the turbos..
Mike
Its really the oil that is being protected by the water lines not so much the turbo. The new air cooled center center section would be a nice improvement on non ball bearing turbos that move a fair amount of oil volume through the bearings. On the ball bearing turbos I would still plumb the water lines.
Old Jan 9, 2010 | 11:02 PM
AWD Motorsports's Avatar
AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !
Originally Posted by IMA Motorsport
Mike and k24madness
Respectfully
We have run water cooled turbos without water on the streets and for drag with no ill effects actually.. Im not sure for long term use or warranty purposes if you dont use the water how it will end up.. The new AiR cooled ceramic BB Billet turbos are working great so far.. Good luck with the setup..
Mike
Old Jan 10, 2010 | 02:12 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
Ivan you have been very busy. Great work and nice inovation. It is good to see IMA taking the lead on bringing this to the market. As usual IMA is a class act with high quality workmanship and attention to detail!
Keep up the great work!!
Old Jan 10, 2010 | 11:08 AM
K24madness's Avatar
Mike
The only real downside to not running waterlines is the need to change the oil more often and reduced turbo life. Depending on the packaging I would eliminate them as well. On my 993 we ran oil through the cooling side with 2mm restrictor. If the air cooled versions were available at the time I would have done those instead.
Old Jan 11, 2010 | 07:06 AM
Comments
K24 and Mike
Thanks for all your input. I am working at the moment on building some headers and running turbos pre cats and doing an after turbo cat and silencer system. This will enable the hp to go has high as you might want to build the motor for. Look for it soon!
Old Jan 11, 2010 | 08:43 AM
3deep's Avatar
3deep is infamous around these parts3deep is infamous around these parts3deep is infamous around these parts3deep is infamous around these parts
K24 and Mike
Now your talking!cant wait to see that setup.Looks like you have some good ideas hopefully your pricing will be equally as good.
Old Jan 11, 2010 | 12:33 PM
heavychevy's Avatar
Any performance or acceleration numbers on this yet? That might sell some people.
Also how much added weight?
Old Jan 11, 2010 | 03:54 PM
DD GT3 RD's Avatar
DD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud ofDD GT3 RD has much to be proud of
first FI kit ive seen for these cars...goodluck to you guys!!!
Old Jan 12, 2010 | 03:38 AM
ADGT3's Avatar
ADGT3 is infamous around these parts
Very Interesting indeed
Now are you planning for the 997.1 and 997.2 the 3.8?
I have the 3.8 and ready to have the TT on the road-map
Old Jan 12, 2010 | 08:00 AM
We are doing the work necessary to mock up and test on 997. Yes our intention is to have it for both variants. We are putting the final touches on the GT3 996 and the standard 996. After that we are going to phase 2 with both models to do headers, cats and mufflers. The 996 system is almost identical to the 997 except for a difference in length on the exhaust pipe. We have 85 to 90 % on solidworks (3d drawing software) for it to be reproduced easy. You can also email me directly at ivan.imamotorsport@gmail.com
Old Jan 14, 2010 | 09:12 AM
Gt3 tt
GT3 Almost ready to go to dyno will keep everyone up to date as soon as we can schedule.
Cheers
Old Jan 16, 2010 | 05:38 PM
997 GT3 starting development soon
We have a donor car to prototype our twin turbo system on. The car should be delivered to us in the next week or so. We are looking foward to this as it should be a real cool set up. The 996 Gt3 is a beast, I can imagine what the 997 would be like.
We are doing a complete set up on 997 from headers, to cats, mufflers, etc.
We will keep you posted on results. 996 dyno results next week.
Old Jan 16, 2010 | 09:21 PM
lakercarrera's Avatar
lakercarrera is infamous around these parts
Just imagine a SW 3.9l with a tt setup...
Old Jan 17, 2010 | 02:54 PM
Thumbs up
Bring it. We can do it. STUPID POWER!!!!
