V1 Directwire question
Old Feb 18, 2010 | 09:54 AM
YoopsRacing's Avatar
YoopsRacing is infamous around these parts
I am getting ready to do this in my GT3. I want to run a wire from fusebox to the rear view mirror area. Do I just need the 8ft power cord (cut one end)or do I need the cord and the directwire power adapter kit?
I will mount it with this:
http://storesense.megawebservers.com...tail.bok?no=71
thanks
Old Feb 18, 2010 | 10:27 AM
Sloopy's Avatar
Sloopy is a glorious beacon of lightSloopy is a glorious beacon of lightSloopy is a glorious beacon of lightSloopy is a glorious beacon of lightSloopy is a glorious beacon of light
From what I understand you need a connector from V1 that is made specifically for this purpose.
I think it has a resistor in it. I had one installed on my RS 60 and the tech called v1 and they said to use their connector that I provided and said something about voltage protection.
Old Feb 28, 2010 | 05:35 AM
trackjunkie's Avatar
trackjunkie is infamous around these parts
you just need a phone cord, walmart sells a black one for $3.xx
There is going to be 6 wires when you cut it open.
Allow for 2 feet of wire.
The green is ground.
The red is power.
Tap into the accessory wire, splice, solder (optional, you can just wrap the wire tightly around), e-tape.
Tap into the ground, repeat steps above.
No need for a fuse.
Old Feb 28, 2010 | 06:57 AM
gt3geoff's Avatar
gt3geoff is a splendid one to beholdgt3geoff is a splendid one to beholdgt3geoff is a splendid one to beholdgt3geoff is a splendid one to beholdgt3geoff is a splendid one to beholdgt3geoff is a splendid one to beholdgt3geoff is a splendid one to behold
No need for anything apart from a telephone cable. Follow this and you will be fine:
http://www.teamspeed.com/forums/997-...e-install.html
PV=nRT.
Sep 9, 2022 06:06 PM
takenotes996tt
Jan 20, 2016 06:34 AM
HotRod
Sep 10, 2015 07:17 PM
pjb84
Sep 2, 2015 12:57 AM
