How "good" is OEM roll cage?
Old Jul 15, 2010 | 11:48 AM
mikymu's Avatar
mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !mikymu Is a GOD !
Question How "good" is OEM roll cage?
Yes, I am finally at the point where I am fast enough requiring a roll cage. It's better to live through a crash than maimed especially this track thing is just a hobby. I like the idea of OEM roll cage since it's not permanently welded but how safe is it compare with a fully welded cage? Race approved?
Oakley's full carbon fiber roll cage is another interesting idea ...
Old Jul 15, 2010 | 12:17 PM
bumperpip's Avatar
bumperpip is infamous around these parts
Thought Oakley was out of business, or otherwise in the weeds ?
Old Jul 15, 2010 | 12:41 PM
GT3 Chuck's Avatar
Administrator
I think you mean the oem roll bar system as it is not really a cage since it has no side impact protection....the first thing you want to check is to see if your RS has the front mounting plates for a cage...if not they will have to be welded in...I really think a call to James Safronas or Fabryce at GMG will put your mind at ease...find out what protection they are using in their WC cars and consider that...
mikymu's Avatar
?? no idea. That will be a shame if they went under
Old Jul 15, 2010 | 01:40 PM
Sloth's Avatar
Sloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud ofSloth has much to be proud of
The only OEM rollcage is the Clubsport cage (front and rear sections) which requires the floor plates to be welded or bolted in place... unless your lucky enough to have one of the early cars which already had the plates mounted from the factory. However, the Clubsport cage doesn't include side impact bars. Otherwise you have the OEM Techquipment bar which is strictly a bolt in affair for the rear part of the car only. Those are the only OEM options and they are special order from Europe only. There are aftermarket options, but any full cage is going to require some welding or drilling of the tub.
Old Jul 15, 2010 | 04:38 PM
GT3Ranger's Avatar
GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !
Same here, I thought after the Farnbacher-Lole debacle Oakley was in the weeds?
Anyway that Oakley rollcage seems weird because there's no crossbar between the C-pillars which I would think is an integral part of structural rigidity. Plus where do you fasten your shoulder harnasses? I hate that
**** of attaching them to the floor of the tube behind you.
Bottomline I don't like it. I think it also cost = to one of your ********* if I remember.
Ranger
Old Jul 16, 2010 | 11:48 AM
mikymu's Avatar
The newest OEM roll cage has door bars as shown below but it does not have the cross beam knee bar between A-pillar to protect you in case of side impact
Cross knee bar is something SCCA require as far as roll cage goes
Here is one P-car without knee bar and look at how far the driver side A-pillar got pushed in with side impact. strong door bars is very important too
Here is a 964 with knee bar above the steering column
Old Jul 16, 2010 | 01:33 PM
GT3Ranger's Avatar
Interesting:
Now how does the dash and instrument cluster figure in with this bar set up?
Never seen it this high but normally below the dash between the A-pillar bars.
When you get this far it ceases to be a street car.
Ranger
Old Jul 16, 2010 | 02:20 PM
mousecatcher's Avatar
mousecatcher is just really nicemousecatcher is just really nicemousecatcher is just really nicemousecatcher is just really nicemousecatcher is just really nice
When you add a cage at all, it ceases to be a street car. A full cage is very dangerous on the street.
Old Jul 16, 2010 | 08:31 PM
Considering that bolt-on is the only way for aluminum framed/tubbed cars to attach a roll cage, it should be of equivalent safety or nearly so. However most SCCA classes require a welded in roll cage unless the frame is aluminum. Wherever you're planning to race may have different rules but SCCA is a good guideline.
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
Vellano Wheels
Other British Cars
Nov 25, 2015 08:57 PM
alevine
Nov 4, 2015 10:05 AM
Vellano Wheels
Other British Cars
Aug 26, 2015 11:06 AM
