Catastrophic Coolant Hose Coupling Failure Registry
Old Sep 21, 2010 | 05:40 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
I would like to limit this registry to strictly people who have had this problem. It would be great to see just how expansive this issue really is. This is a serious problem and could easily result in a fatality under the right circumstances. Please avoid discussing the problem and post questions etc elsewhere so that the thread does not get diluted.
The posts should read as follows:
Circumstances surrounding failure:
Specific Coupling:
Repair Solution:
Old Sep 21, 2010 | 05:41 PM
2007
GT3
8500ish
Turn 17 at Sebring Raceway
Top driver's side behind the alternator
Engine is currently out. Will update thread when repair has been completed.
Old Sep 22, 2010 | 08:08 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
Just a word of advice when removing coolant hoses, the retaining clips that hold each individual hose in place are not all the same... just remember where each one came from when putting things back together, because you can put them in the wrong place and it may feel locked in but when it gets hot and pressurized you will know of your mistake.
-kyle
Old Sep 22, 2010 | 08:49 PM
sharkster's Avatar
happened to a lot of us deputydog A few 997TT's and lot's of 996TT's as well...
Old Sep 25, 2010 | 09:19 PM
So what is the recommended fix for those of us that aren't close to your shop? The dealer wants to just replace the one offending part. That leaves 5 others to fail.
Is spot welding an option?
Old Sep 26, 2010 | 09:19 AM
GTrcer's Avatar
GTrcer is infamous around these parts
I had a coolant failure as well on my 2011 GT3 RS
Had a coolant hose failure after the first track day.
Old Sep 26, 2010 | 11:55 AM
Since either this problem isn't happening to the people on 6speed or the 6speeders just aren't driving hard enough....
See this thread I started on Rennlist. May be a better repository for anyone that has had an issue.
http://forums.rennlist.com/rennforum...-registry.html
Porsche is really taking a laid back approach to this problem. I think its time the owners step up and see if we can get a more appropriate response out of Porsche NA.
Old Sep 28, 2010 | 03:16 PM
thebabydoc's Avatar
thebabydoc is infamous around these parts
happened to my 2004 x50
PV=nRT.
Sep 9, 2022 06:06 PM
nick49
Jan 26, 2017 01:17 PM
faiz
Sep 2, 2015 08:43 PM
