Ceramic disk fell off in the GT3 front caliper
SubscribeAnyone have a pic of what the cup car pieces look like?
Quote:
Look back a couple posts - lots of pictures. I just ordered some for front today from Orbit Racing.Originally Posted by Louis Gigliotti
I saw those, wasnt sure if that was the cup car pieces or not! Thanks
Quote:
Attachment 165301
Attachment 165302
Attachment 165303
Attachment 165304
Attachment 165305
Hey Larry,Originally Posted by landjet
Here are pictures of the solution. The inserts are available through www.orbitracing.com, phone 5618402109. They are called brake puc holders, they don't list a part number on my invoice.Attachment 165301
Attachment 165302
Attachment 165303
Attachment 165304
Attachment 165305
I am getting ready to order a set of these but had a quick question. Do you have to pop out the ceramic disc from the piston in order to install the retainers or can you just push the puck holder into the hole through the ceramic disc? The reason I ask is that only one of my ceramic discs is loose right now and I'd rather not try to pry them loose. Also, I see that you don't run the dust boots in the calipers anymore. Have you had any issues not running them? I replaced mine last time but after 5 track days they are all cracked and fried. I was just a little worried about washing the car and water getting in around the pistons and causing rust without the dust boots. I guess if they're cracked water will get in there anyway so it doesn't matter.
thx....
I'm curious to know if anyone has a source to replace the actual ceramic pucks. Friend of mine had one crack during a pad change and is having a hard time finding a replacement for his 07 GT3 with PCCBs. Any links/input appreciated, they are not offered through Porsche.
