Need Some Technical Advice
Old May 6, 2011 | 08:39 AM
ScooterP's Avatar
ScooterP is just really niceScooterP is just really niceScooterP is just really niceScooterP is just really nice
My 2007 GT3 at idle seems to be a little uneven with the tach bouncing a bit. Seems like a bit of a misfire, but nothing major. No issues at speed, but just a little uneven at idle. Is this normal on the GT3? My C4S that I sold was silky smooth at any speed. Just wondering if I should get this checked out, or I am just a nervous noob.
As always, thanks for all of the help from the 6speed community.
Old May 6, 2011 | 10:11 AM
Swiss made's Avatar
Swiss made is infamous around these parts
My GT3 is also 2007 and does that too. It's even worse when it's cold.
Old May 6, 2011 | 10:26 AM
ScooterP's Avatar
Could be the nervous nature of these engines. They like to be a lot higher in the RPM band! I think I might be worrying too much. These cars are rock-solid.
Thanks for the help.
Old May 6, 2011 | 10:30 AM
Swiss made's Avatar
I know everything is ok with my GT3 because it just came back from my dealer. They did the 111 points check and extended warranty for 2 more years. So i'm pretty sure the nervous idle is normal.
Old May 6, 2011 | 10:41 AM
jakegt3's Avatar
jakegt3 is infamous around these parts
Normal, I think.
Old May 6, 2011 | 10:54 AM
bbywu's Avatar
How many miles do you have on your current coil packs and plugs?
bob
Old May 6, 2011 | 11:51 AM
ScooterP's Avatar
bob
I have 9,300 miles on the car in total, so pretty low miles on the coil packs and plugs. However, the manual recommends that the plugs get changed out after four years which has not been done. Not sure if age is going to affect them as much as miles driven, but I could be wrong.
Thanks for the feedback.
Old May 6, 2011 | 12:18 PM
chardonet's Avatar
chardonet is infamous around these partschardonet is infamous around these parts
Normal. 11,000 miles on mine. Still does it since new.
Old May 6, 2011 | 12:40 PM
sharkster's Avatar
The idle is always a little rougher than on other P-cars. The cams etc.. but if it's hunting around a lot then there's a possibility that a vacuum leak has developed?
Old May 6, 2011 | 01:34 PM
ScooterP's Avatar
I would say it is not hunting around a lot. It is bouncing about 100 RPM at idle - just enough to make the needle bounce a bit.
Thanks for the help!
Old May 6, 2011 | 01:54 PM
jakegt3's Avatar
Yup, +/- 100 rpm at idle is just about what mine does. It's enough that you can feel it. Every other Porsche I've driven has a much smoother idle, but they don't rev like the GT3 either.
Old May 6, 2011 | 02:38 PM
ScooterP's Avatar
Agreed. These cars are fun to take up through the rev band! I am really having fun with this one vs. the C4S, but I already need a new front lip - too many scrapes alreay on low spots. This takes some getting used to.
Old May 6, 2011 | 02:39 PM
sharkster's Avatar
OK yup that's a-ok then
Oct 6, 2015 06:13 PM
flewis763
Oct 4, 2015 04:14 PM
gjpearce
Sep 30, 2015 04:26 AM
NBoost
Detailing
Sep 29, 2015 10:06 PM
lgl314
Sep 28, 2015 04:17 PM
