those w/ PCCB wear issues...
Old 04-19-2005, 01:59 PM
ben, lj's Avatar
Senior Member
ben, lj has a spectacular aura aboutben, lj has a spectacular aura about
Dealer contacting PCNA and they said the pads should be fine.
Old 04-19-2005, 02:27 PM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
Ben,
Do you ever hear any 'metallic-like' noises when you brake lightly?
Old 04-19-2005, 03:15 PM
ben, lj's Avatar
Senior Member
Originally posted by rmrmd1956
Ben,
i did once back around 600 miles ago.
btw, here are the crappy pis i took today (note the cracks):
Old 04-19-2005, 08:20 PM
raygr's Avatar
raygr is on a distinguished road
I am concerned that the worn pads may harm the rotors. That would be more $$$ to fix.
Old 04-19-2005, 08:26 PM
ben, lj's Avatar
Senior Member
Yeah, me too. Rotors are $14k for the front vs. $700 for pads. That's why I ordered new pads today (if they disintegrate as PCCB pads are prone to do when cracked, the resulting metal to rotor could be ugly). I'm pretty sure I'm just going to put them on unless someone with PCCB experience is confident the current ones are fine. Then again, it's a real PIA getting the car on the lift, it's already on the lift, the wheels are off, the pads are out, and it would probably make sense as well from a labor standpoint to just put the new ones in.
Old 04-19-2005, 08:47 PM
raygr's Avatar
Ben, are you doing the pad replacement yourself? Is the car on your own lift?
Old 04-19-2005, 08:51 PM
raygr's Avatar
Btw, did you check your rear pads? I found on my Stradale, the rears seemed to get more wear than the fronts.
I concur on replacing the pads sooner than later. Why quibble over $700.
Old 04-19-2005, 09:01 PM
ben, lj's Avatar
Senior Member
the car is at the dealer - my lift (when it comes) won't be the kind i can use with the tires off. also, you need special plates (pretty expensive and from porsche only) to attach to the lift points on the car (and then it has to be tied down lest the car flip over backwards!). the car was in for tires anyway (which i obviously can't do myself) so the pad exchange is not that big a deal. the rear pads seem fine (all black, thick, etc). it's surprising to hear your stradale wore the rears more than fronts!
matt2ace
11-23-2019 11:38 AM
Glasgo
11-30-2015 02:37 PM
longboarder
10-28-2015 12:10 PM
alpha motoring
10-02-2015 12:04 PM
PelicanParts.com
09-25-2015 03:17 PM
Quick Reply: those w/ PCCB wear issues...
