Difference between 3.6 and 4.0 RS transmission!
Old Oct 24, 2011 | 05:50 AM
motoharu's Avatar
motoharu is infamous around these parts
I hear they change the 997.1 cup cars gear wheels (not the total transmission) with 4.0 ones as they are shorter/better?
Know anything about this?
What are the difference, is it a worthy mod for a no daily driver.
Got my GT2 seats installed and out goes the Euro Buckets, pix coming soon..
Old Oct 24, 2011 | 06:27 PM
jbigelow_1's Avatar
jbigelow_1 is just really nicejbigelow_1 is just really nicejbigelow_1 is just really nicejbigelow_1 is just really nicejbigelow_1 is just really nice
Motoharu - R u interested in selling the 1 piece carbon clubsport seats?
Old Oct 24, 2011 | 08:19 PM
GTgears's Avatar
GTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond reputeGTgears has a reputation beyond repute
Cup Car gears are sequential. They aren't used in any street car. Not even close to compatible with the street box.
Is your question whether or not the ratios between a 997.1 GT3 and a 4.0 GT3 are different?
Old Oct 25, 2011 | 08:40 AM
motoharu's Avatar
@GTgears: I think that's what i mean.
I hear the gear ratios are shorter in 4.0 and you can swap parts with 3.6 without changing the transmission completely.
I think two parts are needed; One tube like part, a small gear attached to one end and one large gear.
There must be a name for it other than short shift gear linkage, but i do not know.
Is it clearer now?
Old Oct 25, 2011 | 01:02 PM
GTgears's Avatar
I suspect you are talking about the ring and pinion and the final drive ratio. The 4.0 got the 3.89 final drive. The other cars run a 3.44. That's the biggest single difference between the two gearboxes.
The 6th gear ratio was tweaked a little bit because of the shorter r/p and made taller, but otherwise the lower gears are identical.
Old Oct 26, 2011 | 02:16 AM
motoharu's Avatar
Exactly, ring and pinion
So there is not much of a difference and not worth to dismantle the transmission?
Thank you for the info..
Old Oct 26, 2011 | 10:05 AM
sin911's Avatar
sin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond repute
I'd suggest R&P upgrade along with an LSD rebuild from Guard while you're at it
Old Nov 2, 2011 | 01:36 PM
motoharu's Avatar
Hmmm, i guess what i want to learn is, not the gt3 rs 4.0s ring and pinion but the 4.0 ratio r&p instead of 3.44 standard cars use..
Is it a good modification, are there downsides (LSD rebuild?), what do you guys recommend?
Should one get into that or leave it alone as it might bring more trouble in the long run?
@gtgears, there is a 1yo thread where you mention a new r&p, 4.12ish, is that product still being developped, updated, tested?
Where should one can order such units in NY or online and delivered to NY?
Old Nov 2, 2011 | 01:51 PM
GTgears's Avatar
Hello Motaharu,
Since our parts are far from DIY components, they are not generally available for "mail order". New York is a big state. Narrow it down a little bit and I'll steer you towards one of our dealers who is able to do a proper ring and pinion installation.
The 4.125 ring and pinion has been on the market for at least a year. We also are now making 4.00 ring and pinions for racers who have to follow homologation rules. If it's for a street car/track toy I personally would be putting in the 4.125 version.
Old Nov 2, 2011 | 08:47 PM
motoharu's Avatar
Hi Matt,
Thanks for the reply, i've send you a pm..
Old Dec 1, 2011 | 11:44 PM
Turbo Fanatic's Avatar
Aren't straight cut gears very noisy?
Old Dec 5, 2011 | 10:23 AM
GTgears's Avatar
Yes they are, but I don't see anywhere in this thread where we're discussing doing that.
HotRod
Sep 10, 2015 07:17 PM
BauerR
Sep 4, 2015 10:47 AM
The Oss
Aug 24, 2015 08:19 PM
