Modest track mods for GT3.1
Old Jan 28, 2012 | 07:25 AM
m3995's Avatar
m3995 has a spectacular aura aboutm3995 has a spectacular aura about
All, I have a '07 GT3, looking to do some modest track mods to strengthen weaker stock parts. I track 6 - 8 times per year and am concerned about wear and ultimate failure of OEM Porche parts. What parts see the most wear and which should be replaced? Thanks!
Old Jan 28, 2012 | 08:06 AM
Misanors4's Avatar
Misanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant future
If you're worried about failure, the biggest concern would be the coolant fitting on the motor the pops and dumps all over your rear wheels causing serious spins and accidents for not only you, but everyone behind you. This doesn't happen a lot, but it is on the list of "failures" A lot of people go with the dogbones/toe links/bump steer kits to get rid of the rubber bushings in the suspension. Get a track alignment from a shop who knows what they're doing and have fun. Keep flushing your brakes every so often as well. Out of the box these cars are great.
Old Jan 28, 2012 | 01:58 PM
Pointby's Avatar
Pointby is infamous around these parts
Originally Posted by Misanors4
If you're worried about failure, the biggest concern would be the coolant fitting on the motor the pops and dumps all over your rear wheels causing serious spins and accidents for not only you, but everyone behind you. ...
Any idea on the cost for that fix? I'm in the same boat as the OP. Already have done dogbones and good alignment, plus Tequipment seats and bar. And I assume the potential issue exists on a 2005 GT3
Old Jan 28, 2012 | 02:23 PM
NorthVan's Avatar
It ranges from shop to shop, but I have seen a $2000 average. Engine needs to come out, coolant drained, about 2 days of work.
Old Jan 28, 2012 | 02:27 PM
NorthVan's Avatar
Other mod that is common is replacing the shifter cable with one from a 996 Cup Car. I am also doing brake caliper stud conversion. I had the LF caliper bolt strip out of the Knuckle on my 997C2S under heavy braking on the track.
Old Jan 29, 2012 | 08:55 AM
m3995's Avatar
Changes and cost of new dog bones?
Did you see a change when you went with the new dog bones? What were the costs? Thanks for all the help.
Old Jan 29, 2012 | 01:39 PM
sin911's Avatar
sin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond reputesin911 has a reputation beyond repute
For track use:
1- get your LSD rebuilt by Guard Transmission.
2- rear toe links (I would suggest getting rid of pretty much all the rubber in the suspension)
3- GT2 rear sway bar (thicker than .1 rear bar, reduces initial understeer)
4- coolant pipe fix is also important as other people mentioned, if you do this try to replace the RMS as well
I'm thinking about doing the 996 cup shifter cable as well.
Old Jan 29, 2012 | 06:59 PM
jakegt3's Avatar
jakegt3 is infamous around these parts
IMHO if you haven't done it already, your first mods should be safety mods: 6-point harness, roll bar, HANS, and seats with pass-through holes for the harness.
Old Jan 29, 2012 | 07:18 PM
Thomas9181's Avatar
Thomas9181 is infamous around these partsThomas9181 is infamous around these parts
+1 on the safety.
Then spend the $$ driving lessons.............
Ever see David Murray kill a Gt3 in an SC???
Jul 29, 2019 11:13 AM
nlakind
Nov 6, 2015 10:15 AM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
Rez90
Aug 24, 2015 09:53 PM
TrackOne
Aug 20, 2015 12:56 PM
