996 GT3 will not rev above 2k rpms
Old Apr 25, 2012 | 08:56 PM
Mcgyver's Avatar
Mcgyver has a spectacular aura aboutMcgyver has a spectacular aura aboutMcgyver has a spectacular aura about
It stalls if you add gas and makes an incredible amount of noise. It has 29k miles. I pulled the MAF sensor and sprayed it with no success. Likely a fuel pump issue or torn fuel pump hose. I will report back when I know more.
Old Apr 25, 2012 | 09:14 PM
GT3 Chuck's Avatar
Administrator
no check engine lights? sounds like it is running in limp mode...not likely a fuel issue...more likely an intake issue or crank position issue
Old Apr 25, 2012 | 09:26 PM
Mcgyver's Avatar
Correct. No CEL. Thanks for the other information.
Old Apr 25, 2012 | 11:53 PM
mooty's Avatar
mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !
i had similar issue.
it was due to some wiring short circuited and burnt out the ecu.
i hope your issue was not as dramatic.
Old Apr 26, 2012 | 10:57 AM
GT3 Chuck's Avatar
Administrator
there is always the possibility that a mouse has been dining on your wiring
Old Apr 26, 2012 | 11:53 AM
Mcgyver's Avatar
Ahhh, good point, but garaged and no visible droppings.
Old Apr 26, 2012 | 01:10 PM
techart996's Avatar
techart996 is infamous around these parts
still might be a failed MAF
Old Apr 26, 2012 | 06:43 PM
AudiOn19s's Avatar
AudiOn19s is infamous around these parts
I'd check for the split fuel hose in the tank. Many reports of failures with similar symptoms
Old Apr 26, 2012 | 06:58 PM
DHI's Avatar
DHI
DHI is a jewel in the roughDHI is a jewel in the roughDHI is a jewel in the rough
Split hose on the fuel pump assembly. +1
Sounds crazy, but it happened to me.
Old Apr 27, 2012 | 06:37 PM
Mcgyver's Avatar
Fuel pump replaced - Fixed!
<end of thread>
Old Apr 27, 2012 | 10:21 PM
GT3 Chuck's Avatar
Administrator
that's good news...glad it wasn't something major...give some rep to those that put you on the right track
Old Apr 27, 2012 | 10:28 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
That's great. Good to hear it was minor.
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 25, 2015 03:27 PM
PelicanParts.com
996 Vendor Classifieds
Aug 18, 2015 03:45 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 18, 2015 03:43 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
