Sport Button
Old Oct 25, 2012 | 08:27 PM
HarmonyJim's Avatar
HarmonyJim is infamous around these parts
Sport Button
When the "sport" button is engaged on my 997.1 GT3RS, is there any added wear going on due to cam lift (Vario-cam) being higher than normal (off sport button position)? Is it best to keep it disengaged when freeway droning? Is gas mileage negatively affected? Thanks in advance.
Old Oct 26, 2012 | 03:18 PM
matrog's Avatar
matrog is infamous around these parts
I believe it just opens a flap inside the exhaust so no effect whatsoever on engine.
Old Oct 26, 2012 | 04:04 PM
D-UberCars's Avatar
D-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud ofD-UberCars has much to be proud of
Different s/w mapping. Doesn't offer much on an NA motor. Neither does the sport chrono wart on the dash = expensive timer.
Old Oct 26, 2012 | 10:25 PM
HarmonyJim's Avatar
I heard it adds 15 hp to the midrange. If that is the case, more than just the flapper is opening I would think. D-ubercars, I hate to sound ignorant, but what is s/w mapping? Thanks again.
Old Oct 26, 2012 | 10:56 PM
RAudi Driver's Avatar
RAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud of
software remapping.
Old Oct 26, 2012 | 11:15 PM
Dr. Bill's Avatar
Dr. Bill is a glorious beacon of lightDr. Bill is a glorious beacon of lightDr. Bill is a glorious beacon of lightDr. Bill is a glorious beacon of lightDr. Bill is a glorious beacon of light
Check the owners manual, but I think all it does is sharpen the throttle response, open the exhaust valve, and increase the threshold for PSM intervention. No extra power.
Old Oct 27, 2012 | 09:31 AM
HarmonyJim's Avatar
Does the software remapping then instruct the Vario-cam to remain on the "high-lift mode" longer, and at a wider range of rpms, thereby increasing wear-and-tear on the valvetrain? My concern is miles of droning along the freeway needlessly increasing wear, as well as burning more fuel (increased fuel injector duration?). If it is merely a change in timing vs lift, or in ignition timing (as long as this doesn't result in higher combustion chamber temps), then maybe it is no big deal. Thanks for the patience on this issue.
Old Oct 29, 2012 | 08:41 AM
Mr. B's Avatar
Mr. B is a name known to allMr. B is a name known to allMr. B is a name known to allMr. B is a name known to allMr. B is a name known to allMr. B is a name known to all
Sharkwerks
If you had the Sharkwerks exhaust you would WANT to engage the Sport button EVERY time.
Mr. B
Old Oct 29, 2012 | 10:50 AM
HarmonyJim's Avatar
Mr.B, I do indeed have the Sharkwerks rear exhaust bypass installed, but I was asking regarding the mechanics of what is going on with relation to the cam lift and/or timing, etc. Thanks for the reply though.
Old Oct 29, 2012 | 10:24 PM
montreal red's Avatar
montreal red is infamous around these parts
would be interested to know this as well.... especially since i drive with sport mode on A LOT... only time i turn it off is when i am driving on the highway for a long time (maybe more than 1 hour).
otherwise sport mode is so addictive... how do you NOT have it on?? i also have the sharkwerks rear bypass installed...awesome little piece.
RallyBird
Oct 7, 2015 01:20 PM
MIK911
Cayenne 958
Sep 26, 2015 12:09 AM
Superaudiofreak
Sep 4, 2015 03:22 PM
