Spring Startup
Old May 5, 2013 | 02:37 PM
bkcarrera's Avatar
bkcarrera is infamous around these parts
Spring Startup
I am about to crank up my '10GT3 stored in a heated garage for a few months.
Can someone tell me what and where a relay or fuse is that I could remove allowing the engine to turnover without starting?
Thanks for any tips.
Old May 6, 2013 | 04:24 AM
ur20v's Avatar
ur20v is a name known to allur20v is a name known to allur20v is a name known to allur20v is a name known to allur20v is a name known to allur20v is a name known to all
Why? Unless you strip, clean and assemble dry the engine the oil will be everywhere needed. Spinning over with the fuel pump fuse pulled will do just as much damage and that is negligible.
Your call if you just want to 'feel' happier doing it as 'it can't hurt'?!
Should be in the hand book and I think its either C2 or C4?
Cheers
Jay
Old May 6, 2013 | 05:48 AM
bkcarrera's Avatar
Thanks - Plus, I'll be on the road quicker that way.
DannyK
Ferrari
Nov 27, 2015 05:56 PM
Jd1368
Oct 16, 2015 09:48 AM
Ronny-
Oct 1, 2015 10:40 AM
PelicanParts.com
Sep 25, 2015 03:17 PM
kensilver
Sep 17, 2015 04:03 PM
