Intake option
Old Jun 18, 2013 | 01:25 AM
chinaman247's Avatar
chinaman247 is infamous around these parts
Intake option
I know the gt3 are great cars stock but I still want mods if I'm able to get some extra ponies.
I like the K&N intake due to the enclosed container but I can't believe majority of the owners opt to keep the stock box and run k&n filters instead.
I heard the drop in filters nets no gains but manufacture claims the K&N intake will produce 8hp wiithout tune and 24hp with tune?
So no one on here has ever dyno tested this intake in the past 6 yrs?
Old Jun 18, 2013 | 01:28 AM
RAudi Driver's Avatar
RAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud ofRAudi Driver has much to be proud of
I had the K&N Filter charger kit. Removed and sold it for $100.
I run the stock box with the stock filter. It's good enough. K&N lets in too much dirt for my tastes and I like engine preservation.
Old Jun 18, 2013 | 01:36 AM
thanks for the reply. Did it show no improvements or was it just making your engine bay blacker faster? I thought the the charger has an enclosed box so wouldnt the rest of the engine compartment be blocked off?
Old Jun 18, 2013 | 06:01 AM
Misanors4's Avatar
Misanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant futureMisanors4 has a brilliant future
If you really must put on an intake, look at the oem RS airbox or the cup air box. Do it right the first time or don't do it At all
Old Jun 18, 2013 | 02:38 PM
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
Skip and go for exhaust. I have akrapovic on my car and love it. I also added bmc air filter
Old Jun 18, 2013 | 02:53 PM
ghst868's Avatar
ghst868 is infamous around these parts
Go with an exhaust as first mod. I recently bough the Fabspeed competition intake from a friend for a really good price. Thats the main reason I bought it.
Im not expecting any HP gains from the intake but it has changed the sound of the car and looks much better than the OEM air box.
I will be dynoing my car next week. I will post the results if you are interested
Old Jun 19, 2013 | 01:51 AM
rbt's Avatar
rbt
rbt has a spectacular aura aboutrbt has a spectacular aura about
You will get heat soak from any aftermarket setup that is not closed up like the OEM box, and the power will then drop. Get the BMC filter with the stock airbox, that is the best option. GruppeM airbox might give some more power, but the price is just wild.
The OEM box has been proven to provide enough air to get 430hp+++ from the 996 GT3 when tuned, so it does not restrict the power one can hope to get out of that engine.
I once did back to back dyno with rear lid open with OEM airbox and then with NO airbox/filter, and the latter lost HP - that is heat soke for you. That is for me proof that the closed box is way better than anything open or with a "heat shield" that is not enclosed for cold air.
Old Jun 19, 2013 | 12:51 PM
TurboLover's Avatar
TurboLover has a spectacular aura aboutTurboLover has a spectacular aura aboutTurboLover has a spectacular aura about
How much better is the BMC filter versus the OEM one though?
Old Jun 22, 2013 | 12:03 AM
Heat soak is a big issue but what if u use those yellow heat resistant wraps and cover the outside for the K&N charger and box? Since it's already enclosed I would think this option would work better compared to oem. The oem box is too big so it's not getting constant fresh air flow since trapped hot air is also circulating. Therefore, if we can keep the engine bay heat away then I dont see why the K&N charger wouldn't be better. The results from kn dyno proves the intake work but once it's heat soaked it's a different story.
Also, I already have the sharkwerk muffler bypass exhaust. Fabspeed stated in an u tube video that the bypass mufflers looses hp compared to stock? Is that true?
Old Jun 22, 2013 | 12:09 AM
anything is better than paper oem filter but if u plan to change the oem one every 3-6 months then oem will work without issue since it's cheap. It seems like a lot of ppl on here also only use their BMC filters once instead of washing and reusing...I guess it's a cheap investment to have a better peace of mind. Overall BMC/KN drop in filters will not show any gains compared to oem filters.
COBB Tuning
Jan 1, 2025 09:02 AM
spreeon
Aug 27, 2015 08:14 PM
PelicanParts.com
Aug 26, 2015 04:25 PM
