Unobtainium 991.2 GT3RSTi X-Pipe
Old Jan 9, 2020 | 02:58 AM
HKFEVER's Avatar
HKFEVER is a name known to allHKFEVER is a name known to allHKFEVER is a name known to allHKFEVER is a name known to allHKFEVER is a name known to allHKFEVER is a name known to all
Have been waiting this custom made Ti X-Pipe for months.
Finally it was done and received this picture from Chris last night Can't wait to put it on
Old Mar 19, 2020 | 12:33 PM
HKFEVER's Avatar
I bought GMG stainless steel X-Pipe with heat treated coating, but didn't have change to install as it is almost as heavy as OEM muffler.
Then I also purchased GMG Titanium version, which is paper light, but the welding is not so good, especially at the join middle pipe.
But compare to Unobtainium's, Unobtainium is true X Pipe, GMG is only 2 pipes joined with as 1" mid pipe.
Unobtainium has much better welding.
Unobtainium is thicker, and a little bit heavier.
So the tone is deeper.
Old May 14, 2020 | 09:19 AM
adamwilla's Avatar
adamwilla is infamous around these parts
so what finally did you set? Take pictures, please
Old May 14, 2020 | 10:53 AM
HKFEVER's Avatar
The first pic: This is after installed Unobtainium X-Pipe
The second pic: This is side by side compare, you can see the Unobtainium's X section is much bigger than GMG's
The third pic: This you can see through Unobtainium's from left to right through the center X section
The forth pic: This you can see the poor cut and oxide weld in the GMG's mid section, this is the mean reason that I change to Unobtainium
Old May 20, 2020 | 10:00 PM
letMeIn's Avatar
5 Year Member
letMeIn is infamous around these parts
when you don't back purge thats what happens. A lot of high end exhaust makers don't back purge their stuff. Its a shame, especially for the $ they are asking.
Unobtainium makes some sick stuff !
Old May 20, 2020 | 10:26 PM
HKFEVER's Avatar
GMG did back purge at some point, the problems are:
- The cutting of that x-pipe holes is not smooth and with cracks!
- They didn't back purge enough when they welded those x-pipe!
Old Jun 23, 2020 | 02:47 AM
HKFEVER's Avatar
Update with some heat treated by exhaust gas
Put the whole hand in the pipe, LOL
Old Jul 2, 2020 | 05:01 PM
egreaves20's Avatar
egreaves20 is a jewel in the roughegreaves20 is a jewel in the roughegreaves20 is a jewel in the rough
Wow, what an exhaust
John@SpeedTech
Aug 21, 2019 10:10 AM
TXGold
Nov 9, 2018 11:49 PM
John@SpeedTech
Jan 30, 2018 05:31 PM
John McLane
Aug 12, 2017 07:30 PM
