Front spring rates-996 GT3
Old Aug 17, 2006 | 01:54 PM
Doctor K's Avatar
Doctor K is infamous around these parts
Did a search function and came up with nothing. I want to slightly increase the spring rate in the front only on my 05 GT3. I have used Eibachs on my old 997 with good results. My front end seems to float more than I like about 100 mph. I know that is a common thing but I also know it could be better.
Any suggestions. H&Rs, Eibachs, others?
Old Aug 17, 2006 | 02:04 PM
Vader13's Avatar
O4 GT3
Vader13 has a spectacular aura aboutVader13 has a spectacular aura about
I think H&R does the stock GT3 coil kit.
Old Aug 17, 2006 | 02:22 PM
LUISGT3's Avatar
Sean,
How did you lower your car?
Old Aug 17, 2006 | 02:44 PM
Vader13's Avatar
O4 GT3
Originally Posted by LUIS95993
Sean,
I had a race shop lower and align it.
Mind Of Motorsports in San Diego (very cool guys)
GMG in OC can do it for you too when you come to OC (they did not have their alignment machine unpacked at the time, so I went to MOM in SD)
Old Aug 17, 2006 | 02:45 PM
LUISGT3's Avatar
I had a race shop lower and align and lower it.
Cool, how much did they lower it? I met Fabryce and the guys at a race in FL. Good guys.
Old Aug 17, 2006 | 02:48 PM
Vader13's Avatar
O4 GT3
Fabio is awesome, I have worked with him for years...
Make sure to set up a time with them before you go to GMG.
They are always slammed.
MOM basically dropped it 1/2 front and 1/4 rear from stock.
The handling was alot better after, but the car is harder to drive into malls..lmao
Old Aug 17, 2006 | 04:37 PM
GT3 Chuck's Avatar
Administrator
if your front end is "floating" at 100mph it's not because of your spring rate...and it's not a common thing for GT3's...you've got something else going on...
Old Aug 17, 2006 | 09:06 PM
Holger B's Avatar
Holger B is infamous around these parts
Ride height and/or alignment may be off.
Also try a Cup lip before changing springs.
Old Aug 19, 2006 | 06:27 PM
Doctor K's Avatar
I have read numerous posts where drivers complained of a front end float on the GT3s. My alignment is right on. Alignment doesn't normally cause the front end to bounce without pulling, or tramlining. Mine does neither.
Old Aug 20, 2006 | 02:29 AM
996GT3's Avatar
996GT3 is infamous around these parts
Just met with Fabryce today at his shop. Very nice guy. Mine will be lowered and aligned to Euro specs sometime next week. Their shop will be relocated to a new facility where Andial used to be.
Old Aug 23, 2006 | 11:13 AM
Bruce's Avatar
Member
Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !
Eurospec
996 GT3- I have a 997 GT3 on order and want the ride height and allignment redone to euro-spec. Where did you get the euro-spec. from?
911TurboRules
Jun 23, 2024 06:59 AM
Enemy
Nov 10, 2015 08:01 AM
alevine
Nov 4, 2015 10:05 AM
The Oss
Aug 24, 2015 08:19 PM
TrackOne
Aug 20, 2015 12:56 PM
