something for the track perhaps?
Old Apr 12, 2004 | 08:59 PM
dpblessing's Avatar
senior member
dpblessing is infamous around these parts
I don't have the car back yet, but I did get to drive it around the block... way cool!!! I pick it up tomorrow afternoon.
Sequential shifter! Yes, that is the rifle bolt like solid accuracy I was refering to a few days ago
Old Apr 12, 2004 | 09:03 PM
dpblessing's Avatar
senior member
It has the electromagnet assist wired through a switch so that it can be disabled to more readily "find" neutral. I think I will leave the console cover off for a few days.
Thanks to James for the clean install (even with me looking over your shoulder) and to all my buds at AkkuratPGI for the work!
It should be a fun toy
Old Apr 12, 2004 | 09:09 PM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Whhhooooaaaaa!!!! Look at that mechanical art!!!! So how is it to shift???? Fast and furious???? Need specifics on that....who makes it??? Approx. cost??? Is it dyi-able???
It would be a shame to cover it up with the console....
Old Apr 12, 2004 | 09:11 PM
rockitman's Avatar
Doug...In a word, that is sick!!!!!
Old Apr 12, 2004 | 09:27 PM
rockitman's Avatar
I think a clear lexan center console is in order!!!!
Old Apr 12, 2004 | 09:32 PM
dpblessing's Avatar
senior member
Thanks Rockitman!
To "upshift" simply pull back. To "downshift" push forward. It only changes one gear at a time in order. It is easier to "shift" with the electromagnet assist "on", but not too bad without. The full "damage" is not yet known, but it should be under $4K.
They do not manufacture it but your buddies at AkkuratPGI sourced it for me and did the install. I think you could DYI it with a bit of patience (I by the way have no patience). Brian (at Akkurat) says you can find neutral between gears to double clutch if desired although I have not done so yet.
I really like the solid mechanical operation.
Old Apr 12, 2004 | 09:39 PM
rockitman's Avatar
Is it hard to switch the electromagnet off to get to neutral when at a light??? How about finding reverse???
Old Apr 12, 2004 | 10:03 PM
cjv's Avatar
cjv
Moderator
Doug,
I can't wait for a report!
Old Apr 12, 2004 | 10:43 PM
KPV's Avatar
KPV
Holy Mother of GOD!!!
Old Apr 12, 2004 | 10:45 PM
dpblessing's Avatar
senior member
Rockit-, we had a simple toggle switch installed to turn off the electro-assist (temp switch for now, but will become an in-dash Porsche switch in the near future). Very easy to turn off - on. A few of the guys at Akkurat have no trouble finding neutral either way, but I guess I do not have the magic touch (yet).
Reverse is very easy... just go down to 1st, then pull up on that ring just below the ball and move the stick. (The ring midway up the stick is for the leather boot and that will go on later.)
Chad, I think you like mechanical things - you should run up to Akkurat (just down the street from Carlsen) and check it out - if you have time. I plan to pick it up between 3 and 4 tomorrow (Tuesday the 13th).
Old Apr 12, 2004 | 11:36 PM
macfly's Avatar
macfly is infamous around these parts
can you swap the shift direction?
I think I'd prefer to shift up with a push 'up' and shif down with a pull down, is it reverseable?
How does it affect the wire operated gear selection?
What is the stress on the system?
How long does it take to have it installed?
Old Apr 13, 2004 | 05:37 AM
rockitman's Avatar
Originally posted by cjv
Doug,
Yes indeed...if this turns out to be as good as we all assume it will be, we need a detailed report full of gore so that we can prepare our bank accounts for another big hit!!!
Old Apr 13, 2004 | 12:54 PM
MJSpeed's Avatar
MJSpeed is a jewel in the roughMJSpeed is a jewel in the roughMJSpeed is a jewel in the roughMJSpeed is a jewel in the rough
Stop it with the teasers... that's just the sickest...BTW is this it: http://www.cartronic-motors.com/e/por_sequ.html
Old Apr 13, 2004 | 01:13 PM
MgnFicnT's Avatar
MgnFicnT is infamous around these parts
now that is pretty cool ! i love it
Old Apr 13, 2004 | 01:45 PM
dpblessing's Avatar
senior member
MJSpeed, yes it is the Cartronic unit
Thank for the link.
