07 Gallardo whistling sound???
Old Aug 15, 2008 | 12:09 PM
monsoonmadness's Avatar
monsoonmadness is infamous around these parts
As a few of you here know, I traded in my 997tt for a 07 Gallardo Nera. I picked it up about a month ago and have had the windows closed since I got it. Well, about a week ago I started driving a bit with the windows down and I am noticing a type of air,whistling noise under light accelaration. When you nail it, it goes away. But when you take off slow in any gear at any speed I am hearing a air,whistling noise coming from the air intakes. Is this a normal thing?? I went to Manhattan motor cars here in the city and they told me its normal.. I am finding that hard to believe. They said that in 06' they changed the throttle body and air box and thats the reason why.
Does anybody else with an 06 or 07 hear this or am I just going crazy!!
Old Aug 15, 2008 | 12:46 PM
DynamicMotoring's Avatar
DynamicMotoring is infamous around these parts
Ive heard it in several cars. Its pretty normal. You could get new airboxes and that will cover up the sound.
Old Aug 15, 2008 | 03:46 PM
As long as its normal I dont care at all.
Old Aug 15, 2008 | 11:32 PM
geeman14's Avatar
geeman14 is infamous around these parts
Normal
Totally normal. Same as my 07 Spyder. I talked to Lambo OC when I first heard it and they said no problem. I think at one point they made a small bracket for another customer to help break up the air and remove the whistle.
It doesn't bother me, so if it doesn't bother you don't worry about it.
G
Old Aug 16, 2008 | 09:34 AM
turbo50mike's Avatar
turbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant futureturbo50mike has a brilliant future
You'll hear that even on the earlier cars - It's simply the air squeaking by the throttle bodies under light acceleration. You also hear it quite clearly with the windows down because the air intakes are those vents above the rear wheels facing forward.
If it bothers you, just press harded on the gas pedal - It's more fun that way anyway.
Old Aug 16, 2008 | 02:32 PM
Sendero's Avatar
Sendero is a name known to allSendero is a name known to allSendero is a name known to allSendero is a name known to allSendero is a name known to allSendero is a name known to all
I have a similar noise in mine but I'd swear it sounds more metallic. Is what you all are talking about?
Old Aug 16, 2008 | 03:46 PM
Naahh....Sounds like yours is broken and falling apart, I'd have that checked out...
J/K
Old Aug 16, 2008 | 04:26 PM
To me it also sounds metalic. But according to Manhattan Motor cars its NORMAL!! I just feel better now knowing that I am OK with that noise. Whenever I take someone for a ride I tell them that noise you hear is the Turbos..
Old Aug 17, 2008 | 09:33 AM
silk55's Avatar
silk55 is infamous around these parts
i also have this on my gallardo
Hybrid
Jun 28, 2024 06:05 AM
Paintballzen
Oct 10, 2020 12:22 PM
Feelgood MD
Mar 24, 2016 09:35 AM
jyupitt1
Sep 10, 2015 08:31 PM
pjb84
Sep 2, 2015 12:57 AM
