Gallardo Shopping, Need Input
Looking to jump into a Gallardo. Any concerns in picking up an 04/05 or should I lean towards an 06? Also e-gear or manual? I have always preferred a manual, however, don't mind e-gear. I will consider this to be a new daily driver, my commute is only 5 miles each way. Any input would be appreciated. Thanks.
04's and 05's are completely fine with a egear ECU software upgrade. Everything can usually be sorted out with minimal cost. the clutches in the 04 egears usually ware out faster depend on driving habits. if the clutch was replaced with a later revision and you have the updated egear ecu upgrade then you don't have anything to worry about. gallardo's are rock solid
