Mini Cooper Austin and Morris Mini talk, and the 2001-2006 Mini and Mini S, 2007 to present Mini and Mini S
Crank but not start
Old Apr 4, 2021 | 05:47 AM
Ivo Denev's Avatar
Ivo Denev is infamous around these parts
Crank but not start
Hi there, I need your expert opinion. I've got mini cooper R56 base model no S, n12 engine. The problem start yesterday when the engine cut off itself as I drove without any errors on the dashboard! Not able to start since then! Towed to home. Scan it for errors and no any errors stored! The LPFP not priming in ignition on! Get 10.9 volts to the fuel pump while cranking and jumps to 12 when starter stops after 5 sec. before returning to zero. Fuel pressure reaches 50 psi over 30 seconds of cranking and drops to zero when stop cranking. Engine never starts even upon reaching 50 psi. I am really confused. Any idea what could be the fault? Cheers!
977ttblue
Apr 28, 2016 10:34 PM
Darth GF
Aug 13, 2012 04:06 PM
ytyper
Tech / How To
Oct 9, 2011 04:41 AM
ytyper
Sep 17, 2011 08:02 AM
Dharn55
Jun 16, 2009 09:23 PM
