TPMS & Floor Jack questions, please
So I asked this at Cayenne forum but had no answer... I thought I would ask the local ppl here instead if I could, please.
Our Cayenne S (08) seems to be giving a false alarm saying left rear tire pressure is too low (-5). I went to gas station and got some air for it.. It was back to normal. As soon as I got home, it showed -2, then -4, and now -5 again. I checked the tire and it was at 43 psi..this morning showed the same thing (43)... So I was wondering if anyone has had this happened before and how do I reset it?
May I also know what's a good floor jack that I should buy and where to buy it (used for Audi sedan and Cayenne)...thanks!
John
John
John
John
As for a floor jack, Costco probably is a good bet. If not there, Sears also sells a good 3 1/2 ton floor jack for under $100. You might also consider a small 120# air compressor from Sears to keep your tires at the proper pressure. You'd be surprised at how much tire pressures vary over the course of just a week.
Thank you, gentlemen. You local folks are always the most helpful ones. I will check out these jacks you mentioned.
Hummm, I use my own gauge as well as TPMS, they both show 43... weird that it still says -5....
Hummm, I just checked out air compressor on Sears.com and there's a few. Which one do you recommend?
http://www.sears.com/shc/s/search_10...&gobutton=find
Thanks.
John
Thanks.
John
That sounds more like a faulty sensor. I have one that sometimes wants to toggle back and forth by 2#'s. Does it ever go below -5#'s?
http://www.sears.com/shc/s/search_10153_12605?keyword=120+air+compressor&gobu tton.x=0&gobutton.y=0&gobutton=find
Thanks.
John
Thanks.
John
OK I guess it's the sensor. Take it back to the dealer, if the car is still under warranty. If not, just live with it unless you want to spend about $125 for a replacement. It could be a little less expensive if you were to wait until you replace your tires.
http://www.sears.com/shc/s/p_10153_1...5310000P?mv=rr
This is good for pumping up tires and could be used with a limited number of air tools. I use mine for blowing water off the car (in the cracks and crannies) after washing it.
