Other British Cars Jaguar, TVR, Rolls Royce, Morgan, Caterham, Noble & Range Rover
2009 rr hse
Old Apr 7, 2011 | 01:44 PM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
2009 rr hse
I am lookng at a 2009 RR HSE that is pretty loaded. It is CPO'd and low mileage. I was wondering if there is anything I should know about this model. I have been a member of 6speed Porache for a while and I just decided to buy this truck and unfortunatly don't have enough time to lurk and learn. Hoping you guys came give me the good, bad and ugly. Help me look at the right things and ask the right questions.
Drove it today and it is pretty fast for such a large truck. Handled well and had more then enough room. it will be my daily driver and I pack on 20k per year easy.
Thanks in advance for your input and guidance.
Old Apr 14, 2011 | 02:03 AM
quattrogeek's Avatar
quattrogeek is infamous around these parts
Early models had problems with faulty air ride suspension, coolant leaks, bad o2 sensors, bad fuel pump, electrical gremlins causing fuses to burn out etc...
Old Apr 22, 2011 | 05:47 AM
JSF721's Avatar
What years are you referring to? Thanks for the reply.
Old Apr 22, 2011 | 02:36 PM
CornersWell's Avatar
CornersWell Is a GOD !CornersWell Is a GOD !CornersWell Is a GOD !CornersWell Is a GOD !CornersWell Is a GOD !CornersWell Is a GOD !CornersWell Is a GOD !CornersWell Is a GOD !CornersWell Is a GOD !CornersWell Is a GOD !CornersWell Is a GOD !
Anything produced after 2006 ought to have the kinks worked out. I waited for an 06 MY HSE (SC'd) and would NOT buy anything built prior to that. Generally speaking, Ford and BMW sorted the suspension and electronics. Mine has been very reliable. The only issue I've had was a leaking radiator, which was covered under warranty. Mine's now out of warranty, and I purchased an independent warranty on it. RR's is CRAZY expensive and much shorter, although the indy wasn't inexpensive, either. I guess they've heard the stories about RR reliability!
VERY comfortable. VERY capable. A LOT more truck than the Sport.
Given that you're on LI, you'll probably go through brakes and tires. Check the wear that's left. Get the dealer to put that in writing, and when they wear out in half the time, you'll at least have something to negotiate with them. Is this from an authorized RR dealer? I wouldn't touch anything that isn't. RRs have CPO. You may find that useful.
CW
Old Apr 23, 2011 | 02:27 AM
kstatenupe's Avatar
kstatenupe is infamous around these parts
I currently have an 09 HSE, and I have not had anything major. The worsk thing I can think of was the dreaded seat rock. When you accellerate your seat will move ever so slightly along the rails. Oh and my power seat motor failed once.
All covered under warranty.
Old Jun 5, 2011 | 05:00 PM
JSF721's Avatar
Car was sold out under me. Pulled trigger on a New Sport. SO far So good. Black, Black. Oh I hate Pollen!
Old Jun 5, 2011 | 05:26 PM
Gotnem108's Avatar
Gotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to all
I have am '04 hse with a BMW engine and so far I've had coolant leaked, air ride suspension, fuel pump, fuel sender, coolant system gaskets and among other minor things fixed. I have only 67k miles on it, and my extended warranty ended back in sept of last year and most started to break down after the extended warranty. So I suggest that you get extended warranty since you will be driving a lot with it. Oh, its a gas guzzler! I've driven a lot of luxury SUVs above 60k range and nothing compares to this. So my truck started to break down at around 60k miles, you should think about the extended warranty since the cost of repair is rediculuos.
Old Nov 26, 2011 | 12:23 PM
legit526's Avatar
legit526 is infamous around these parts
any recommendations on 3rd party warranty?
Old Nov 29, 2011 | 02:02 PM
04Ultrasprt's Avatar
04Ultrasprt is infamous around these parts
I'm looking at picking one of these up for the winter as well, just need to make some room first.
Old Dec 18, 2011 | 09:14 AM
Paul K's Avatar
Paul K is infamous around these parts
I had an '07 HSE. Lots of issues. I have heard that '08 on is the way to go.
Old Dec 21, 2011 | 10:37 AM
sechsgang's Avatar
sechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant futuresechsgang has a brilliant future
08-09 are just fine, but any rover 2010 and up really step up the game with the jaguar/tata bits...
Old Dec 23, 2011 | 01:41 AM
socalbd's Avatar
socalbd has a spectacular aura aboutsocalbd has a spectacular aura about
I recently traded in my '05 HSE on an '08 Carrera 2S. I loved that Rover--until started to fall apart. At 70K mi I spent $5000 in a single month, with THOUSANDS more still needed. Air suspension, radiator, trans cooler, vacuum hoses melted, all kinds of crap. Traded it in with the VERY common steering wheel in the lap issue and the tranny was days away from exploding. Bonatti Grey paint
was falling apart. $8k+ for that. Loved it, then it hit a wall mechanically.
tita1989
Aug 17, 2016 03:13 PM
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
Oscar 987
Sep 29, 2015 04:57 PM
r1rb
Sep 27, 2015 12:06 PM
