iPod interface does not charge iPod or iPhone.
Old Jan 26, 2010 | 06:17 AM
Mojosan's Avatar
Mojosan is infamous around these parts
CORRECTED: iPod interface does charge iPod or iPhone.
Edited: See my last post. The cable DOES charge if you make a "U" connection with the usb cable and loop it back into the usb port.
Thanks to EasyButton for figuring that out.
Ugh.
What a huge inconvenience this is.
It even brings up the dreaded "This device is not intended to work with iPhone" error message.
Now I have to keep a charger, and plug it into the damn cigarette lighter, to keep the phone going.
I have a crossover adapter plug that might work. I'll try it and report back.
Old Jan 26, 2010 | 06:39 AM
Crea's Avatar
Crea is a jewel in the roughCrea is a jewel in the roughCrea is a jewel in the roughCrea is a jewel in the rough
do u have the Y cable with USB port?
Old Jan 26, 2010 | 11:27 AM
Mojosan's Avatar
Yes.
Old Jan 26, 2010 | 05:10 PM
easy_button's Avatar
easy_button is just really niceeasy_button is just really niceeasy_button is just really niceeasy_button is just really niceeasy_button is just really nice
Y cable works... message does not mean it will not charge - there actually is a different message if the phone will not charge. Press 'No' on the pop up and everything should work fine. PCM interface is via the dock connection; charging is via USB. Older iPods only need the dock connection to interface and charge. FWIW a lot of adapters cause the iPhone and other iPods to display the message and work just fine.
Old Jan 26, 2010 | 05:19 PM
Mojosan's Avatar
It works fine, but it doesn't charge.
Both my ipod and iPhone make a distinct tone and display the battery symbol with a lightnng bolt in it.
Old Jan 26, 2010 | 05:53 PM
Sorry for asking again and if this comes off wrong, but are you using the cable that attaches to just the iPod port, or the cable that attaches to both the iPod port and the USB port? The standard cable that only attaches to the iPod port will not charge the iPhone or newer iPods. Unless your dealer swapped it for you, the cable that came with the car will not work.
Old Jan 26, 2010 | 08:27 PM
Cayenne328's Avatar
Cayenne328 is infamous around these parts
iphones require 0.8A to charge.
Old Jan 26, 2010 | 09:21 PM
Fantasma's Avatar
Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !Fantasma Is a GOD !
Old Jan 27, 2010 | 06:09 AM
W8MM's Avatar
Honored Member
W8MM is infamous around these parts
I use one of these in my Tesla for iPhone charging:
http://www.cablejive.com/chargeconverter.html
Older iPods used fire-wire 12volt charging. This gizmo (and others) convert the 12v fire-wire charging to 5v USB charging voltage and apply it to the correct dock connector pins.
Old Jan 27, 2010 | 06:51 AM
Mojosan's Avatar
I got the phone to charge.
You make a "U" connection with the supplied cable and hook the USB end of the cable back into the USB port in the console.
Thanks for the tip easy button. That saves me a LOT of aggravation.
Old Feb 22, 2010 | 12:23 PM
goveil1's Avatar
goveil1 is infamous around these parts
I just plugged my ipod into my new Boxster, and its not charging. What do you mean by "U connection"? Do you mean plug in both the DIN plug and the USB plug?
Old Feb 22, 2010 | 04:22 PM
falb's Avatar
falb has a brilliant futurefalb has a brilliant futurefalb has a brilliant futurefalb has a brilliant futurefalb has a brilliant futurefalb has a brilliant futurefalb has a brilliant futurefalb has a brilliant futurefalb has a brilliant futurefalb has a brilliant futurefalb has a brilliant future
Yes, the power comes from the USB.
Old Feb 22, 2010 | 04:24 PM
goveil1's Avatar
Thank you! I was just about to take it back to the dealier!
calexand
Nov 5, 2015 01:05 PM
Kalvin Chen
Oct 20, 2015 09:18 AM
freddiemac
Oct 7, 2015 11:05 AM
V565MAN
Oct 2, 2015 05:48 AM
ECS Tuning - VW
Sep 25, 2015 02:22 PM
