Adding Oil to the Panamera
Old Jan 12, 2013 | 02:28 PM
ThunderRolls's Avatar
ThunderRolls is a name known to allThunderRolls is a name known to allThunderRolls is a name known to allThunderRolls is a name known to allThunderRolls is a name known to allThunderRolls is a name known to all
FYI - my oil light indicator came on stating that I was at minimum oil operating level, showing all bars in normal range empty. I added one half of a quart and drove it around until it registered (because my service rep advised to add half a quart at a time). When it registered, all bars were full.
Just MHO, but don't just dump a quart in it when it says low like you would do with most vehicles. Apparently the gauge has a very narrow tolerance window.
Old Jan 13, 2013 | 11:37 AM
JMC8's Avatar
JMC8 has much to be proud ofJMC8 has much to be proud ofJMC8 has much to be proud ofJMC8 has much to be proud ofJMC8 has much to be proud ofJMC8 has much to be proud ofJMC8 has much to be proud ofJMC8 has much to be proud of
good info!! Yep the oil sensor had a very narrow window from full to min op level, do half quart at a time.
Old Jan 13, 2013 | 12:10 PM
kip's Avatar
kip
kip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to beholdkip is a splendid one to behold
One segment of the display corresponds to a top-up quantity of approx. 0.26 US quarts. (0.25 liters).
Old Nov 1, 2018 | 09:38 AM
negb's Avatar
negb is infamous around these parts
I have a question: has anybody noticed when oil level is showing all segments (full) and after opening and closing hood and driving those minimum 10km when indication comes back
it shows already minimum level ? Actually I was thinking why after driving more then 2000km oil level wasn't dropping and then I had to add windows washing liquid and that's how I noticed this ''phenomena'' and later confirmed one more time..
Now thinking is ultrasonic level sensor bad or there is some kind reset with opening/closing hood which doesn't make any sense to me.....
Originally Posted by wwilliams88
Oil level measurement is electronic. A measurement can be made with just the ignition on, with the engine running and stationary, or while driving. Measurement is made using an ultrasonic level sensor which measures the thickness of the oil level in the pan by bouncing sound waves off of the oil/air interface at the top of the reservoir and computing the time-of-flight.
Dry Sump lubrication system with the oil reservoir in the engine for space savings.
Old Nov 1, 2018 | 08:47 PM
ciaka's Avatar
I have a thread on this discussing adding oil.
Old Nov 2, 2018 | 01:49 AM
negb's Avatar
I didn't find anything on this forum about immediate oil level indication drop after opening and closing hood...
\would be possible to get a link to that thread ?
Old Nov 2, 2018 | 09:43 AM
ciaka's Avatar
Adding oil to Panamera, oil level, etc, discussed in this thread. Not started by me, but i chimed in few times.
Clickie
Old Oct 20, 2020 | 05:09 PM
1BD944T's Avatar
1BD944T is infamous around these parts
Question...I have 2011 Panamera 4s and nothing happens when I open and close hood after topping off... never recalculates... anybody else have this issue.. I tried after driving the car...After sitting overnight.. Nothing....just shows the old measurement
Old Oct 20, 2020 | 06:04 PM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
how far did you drive?
Old Oct 20, 2020 | 10:52 PM
ciaka's Avatar
After you fill up, the oil recalculation takes 12 miles. During that time it will tell you you cannot check oil and you have not driven long enough.
Dog asked good question, how long did you drive after topping up? and how much did you put in, and what was the level before you added oil?
PV=nRT.
Sep 9, 2022 06:06 PM
ModBargains
997 Vendor Classifieds
Oct 13, 2015 03:53 PM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
m_motorsport
Sep 2, 2015 12:53 PM
