Hit 2000 miles so floored it and saw this..
Old Sep 18, 2013 | 03:17 PM
tom kerr's Avatar
Originally Posted by jaatlee
Well that actually distorts the test results a bit, should have asked you that first, I thought you were bone stock just passing by your 2500 mile recommended vehicle break in period. The addition of the IPD plenum, the replacing the factory cats with 200 cell cats, and the resonator replacement with the X-pipe each will contribute to higher boost values and also help to hold more consistent boost across the rev range, especially on the top end. They are all great mods!
Daytona huh? Pretty sure that you will enjoy this video then. You should see if there any standing mile runs in your area.
Driver Cup. Panamera Turbo vs BMW M5 F10 - YouTube
Jeff
awesome
Old Sep 18, 2013 | 03:28 PM
MIA997TTBeast's Avatar
MIA997TTBeast is infamous around these partsMIA997TTBeast is infamous around these parts
Jeff
Why would the mods "stabilize" the boost? Isnt it computer controlled? So if it sees more air in and out it should still "adjust" and we should see fluctuations.
My PTT fluctuates A LOT between .9-.6. When I saw your post about the diverter valves I thought about upgrading, but if those other mods somehow fix it I would love to know the reasoning behind it.
Let me know, Thanks.
Old Sep 18, 2013 | 07:52 PM
cvprez's Avatar
cvprez is infamous around these parts
That video may be the worst use of 7 minutes of my life I've experienced to date!
Old Sep 19, 2013 | 06:36 AM
jaatlee's Avatar
jaatlee is infamous around these parts
MIA997TTBeast,
I would highly recommend that you replace the BOV/diverter valves if they have not been replaced already as they are seriously prone to leaking! (Best mod under $300 you can get by the way!) The older your car gets the worst the OEM BOV/diverter valves will leak. Even on a stock car if the diverter valves are leaking this will cause significant power loss across the entire rev range due to reduced boost pressure being held at any given RPM.
The OEM catalytic converters are VERY restrictive! Replacing the 700 cell count OEM cats with 200 cell count aftermarket cats will eliminate this restriction while still maintaining the emissions control functionality. The primary benefit of the reduced restriction is that the turbos no longer have to work as hard in order to produce the same amount of boost pressure, which usually results an increase peak boost pressure of at least 1-2psi over whatever the maximum boost pressure was before. The turbo is also able to better effectively maintain a higher amount of boost pressure as a result of the reduced restriction resulting in additional horsepower and torque and more consistent (read less bouncing around) boost pressure being held all the way to redline. The downpipe with 200cell cats are definitely mods you want to do!
Jeff
Old Sep 19, 2013 | 07:33 AM
tom kerr's Avatar
MIA997TTBeast,
Jeff
+1 thanks saved me some typing
COBB Tuning
Jan 1, 2025 09:02 AM
2lflat4
Nov 18, 2019 05:05 PM
97GtsMonster
Nov 17, 2015 12:38 PM
The Oss
Aug 24, 2015 08:19 PM
