Newbie with a small problem!!
Old Dec 29, 2014 | 01:58 PM
RS6chris!'s Avatar
RS6chris! is infamous around these parts
Hi guys
Great forum
Just got myself a 2011 panny turbo!!
Had it about a month now and over the moon with it.
A different drive from my previous mapped RS6...but dynamically sooo much better.
Anyway a small problem has come up today...
It won't let me activate sport mode or sport plus mode?...saying "not available" in display?
No warning lights on dash and car drives fine just can't activate either mode?
Any one had this before? And/or know what it could be?
Thanks in advance
Chris
Old Dec 30, 2014 | 06:42 AM
Samp's Avatar
Samp is infamous around these parts
Never heard that one. Sorry
Old Dec 30, 2014 | 09:14 AM
Logimind's Avatar
Logimind is infamous around these parts
Maybe your suspension is left in "shop" mode. Its where you hold suspension button for 10 sec so you can lift the car. Its a big maybe. I doubt it but try it. Maybe the turned off suspension is not allowing the shocks to drop and disabling sport. Maybe.
Old Jan 1, 2015 | 09:27 AM
RS6chris!'s Avatar
Tried the suspension in fact tried everything sport and sport plus still won't engage....car drives fine.
Can't turn traction control off either??
Help!!
Old Jan 1, 2015 | 09:37 AM
morelli's Avatar
morelli is infamous around these parts
I would suggest disconnecting the battery and waiting about 10 minutes before re-connecting so the computer can reboot. Once done see if that fixes things. I have a truck that once in a while, certain functions stops working. Unplug the batteries, wait, plug back in and all works fine again.
Old Jan 1, 2015 | 11:34 AM
porschecayenne92's Avatar
porschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant futureporschecayenne92 has a brilliant future
definetely the battery . Usually when the car throws codes like these its the battery.Just replace it
Old Jan 1, 2015 | 11:49 AM
RS6chris!'s Avatar
Ok guys thanks
Anything I need to know about disconnecting and reconnecting the battery?
Is it as simple as that?....won't need any kind of reprogramming etc?
Negative to disconnect first?...in trunk?
Leave for a few mins then reconnect?
Of course if this works il still book her in for a new battery?
Old Jan 1, 2015 | 04:24 PM
morelli's Avatar
Yes, negative always first off and last on. The owner's manual will also contain information about procedure for changing battery, just skip the actual swap part. Yes leave disconnected for a few minutes, helps to try and and start while disconnected. Any residual charge will disappear quickly.
Hope that helps.
Old Jan 7, 2015 | 12:45 PM
RS6chris!'s Avatar
Hi guys
Update
Car into porsche
ECU re flashed all is now well
They did mention that a low battery may have caused the issue?...I tried disconnecting etc but made no difference.
Any way happy again
Thanks for advice.
Old Jan 8, 2015 | 08:01 AM
ECS Tuning - Porsche's Avatar
Glad everything worked out and thanks for the update Chris. Post up a few pictures of this beast when you get a chance
Old Jan 8, 2015 | 09:29 AM
RS6chris!'s Avatar
Sweet
Il pop some pics up in a separate thread!!
NC 996TT
Mar 23, 2023 06:19 AM
cdrik915
New Member Introductions
May 14, 2019 11:15 AM
davetherave
Bentley
Sep 11, 2015 04:15 AM
andbos
Sep 10, 2015 10:43 AM
markj
Sep 6, 2015 09:08 AM
