strange problem on my Panamers S
Old Feb 10, 2015 | 08:11 AM
luckydanel's Avatar
luckydanel is infamous around these parts
hi everyone.
I have a Panamera S MY 2010 and have a strange problem.
every time I lock my car and unlock, insert the key, the abs failure, psm failure, fault electric parking brake and check engine tip comes up.
But I pull off the key (I did not turn on the engine), and turn the ignition on, mostly everything gone.
After several time turn on and turn off the ignition, engine check tip won't gone.
Connect with PIWIS after having engine check tip, lot of unit have a common code, "low voltage."
Does it means my battery need to change? Or something else need to check?
Old Feb 10, 2015 | 08:57 AM
dnsacks's Avatar
dnsacks is infamous around these parts
I'd start by getting your battery checked out -- an autoparts store can do this quickly and easily.
Old Feb 10, 2015 | 11:19 AM
Gus_Smedstad's Avatar
Gus_Smedstad is infamous around these parts
While the battery is definitely something to check, that sounds like something you really should check with a mechanic. I'd think that if it were just the battery, you'd have trouble starting the car long before it started throwing all those error messages.
Old Feb 11, 2015 | 01:50 AM
luckydanel's Avatar
Hi guys, just update the state.
Jump the battery this morning and lock the car than unlock. No any error shows up.
Will change the battery tomorrow. ( order a origin battery from local dealer, about $310.)
Will update after replacing new battery.
Old Feb 12, 2015 | 10:36 AM
thefullgarage's Avatar
thefullgarage is infamous around these parts
It's definitely the battery. Had these messages on my Panny '10 before there was ever any signs that it might be battery issues. Once, a message popped up that said "Chassis failure," but thankfully it was because the battery was no good.
Side note: After I replaced the battery I was automatically able to tell the difference with the new battery. The way the ignition sounded when turning on was insane compared to the slowed sound of the ignition with the old battery.
WearyMicrobe
Dec 10, 2015 04:06 PM
cockneymike
Oct 22, 2015 06:00 PM
vogz
Sep 19, 2015 01:02 PM
dailydriver
Sep 13, 2015 09:01 AM
nal991
Sep 11, 2015 09:05 AM
