Exhaust Valve to bypass muffler for Panamera S
Old Feb 25, 2015 | 04:36 PM
JonnyL's Avatar
JonnyL is infamous around these parts
I recently bought a 2011 Panamera S in the UK without the sport exhaust system. From searching the forums I found that a simple way of having a better exhaust note is to keep the valve open by disconnecting a vacuum hose? I presumed I had this vacuum hose to disconnect since that the start up exhaust sound was much louder than idling. Does anyone know weather my panamera will have a valve/flap to open and if so, is it possible if I could get a picture or two locating this hose.
Old Feb 27, 2015 | 06:09 PM
Logimind's Avatar
Logimind is infamous around these parts
I found this: http://www.insanegarage.com/cheap-fr...-sound-louder/
Probably it may help you
Old May 17, 2015 | 09:12 PM
M3putt's Avatar
M3putt is infamous around these parts
I don't think a non PSE has those values, right? This looks like a Porsche Performance Exhaust and a solution to bypass the console button. Has the OP tried this with a non PSE?
Old May 18, 2015 | 08:46 PM
TheBeav's Avatar
TheBeav is infamous around these parts
that's for the normal exhaust. it does have valves that can be opened by disconnecting the vacuum hose.
Old May 19, 2015 | 06:23 PM
EmmHolla's Avatar
EmmHolla is infamous around these parts
I may have to give this mod a try..
Old May 19, 2015 | 08:31 PM
TheBeav's Avatar
it's very simple to just reach down and pull the rubber hose off the nipple. when you don't want the extra rumble just reattach. don't even need to get under the car.
Old May 21, 2015 | 09:08 AM
kelyeung's Avatar
kelyeung is infamous around these parts
Tried it and for all non-turbo cars, the car will feel sloppier and slower as the back pressure is insufficient to make the car go fast. It feels louder especially on downshifts but it makes the car quite slow. Disconnecting the tubes are quite easy, so you all can give it a try. Turbo cars will not be affected as the building of back pressure takes place in the turbos. Not too sure there is a valve for non turbo and non pse cars.. Worth trying it, but I don't think it's worth doing it. Hope this helps
Old May 24, 2015 | 07:35 PM
M3putt's Avatar
Definitely no valves or vacuum tube to disconnect on my 4s with standard exhaust.
Jun 10, 2017 07:45 PM
turbotuner20v
Sep 11, 2015 12:02 PM
Money2536
Sep 1, 2015 04:56 AM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
