Panamera Driver Side Window Switch Issues.
Old Aug 18, 2016 | 10:36 PM
Bart4speed's Avatar
Bart4speed is infamous around these parts
It can be done under CPO. It all depends on your relationship with your SA. Dealers get paid more from a Porsche than if you had to pay for it yourself.
Old Aug 22, 2016 | 10:20 AM
Root's Avatar
Root is a glorious beacon of lightRoot is a glorious beacon of lightRoot is a glorious beacon of lightRoot is a glorious beacon of lightRoot is a glorious beacon of light
Mine was two years old when the chrome piece broke off the driver window switch. Dealer replaced under warranty. It has been OK since then.
Old Dec 23, 2016 | 07:51 AM
negb's Avatar
negb is infamous around these parts
Originally Posted by sayadil
... I noticed new switch is better quality... Also if u notice the child lock sign has changed. I preferred the child logo over the window logo on the new one.
Received mine, 104 euros .....
Name:	7PP959858AEDML - door window switch front left black NEW.JPG
Old Dec 25, 2016 | 01:00 PM
Ride4Life Rossi's Avatar
Ride4Life Rossi is infamous around these parts
Originally Posted by negb
hmmmm, very strange that such breakdown was covered by warranty.... will see what my dealer will say about that, here are pictures attached of broken switch in my Panny
Mine is broken exactly like yours, I got my car like that. Doesn't really bother me. I never would have noticed if the Dealer didn't tell me.
Old Dec 27, 2016 | 12:27 PM
negb's Avatar
))) in a beginning I thought it has to be like that, I thought for easier to find drivers window switch
Old Jan 12, 2017 | 08:17 AM
verdugo135's Avatar
verdugo135 is infamous around these parts
May be taboo, but have you guys noticed the chinese have replicated this part, possibly due to the crappy oem quality (always breaking). My first panamera came with a broken switch. I picked up a chinese aftermarket one on ebay for like $40. I attempted to remove the door panel per a youtube video, but after following all the instructions, I couldn't get the door panel to pop off. I ended up removing the speaker grill by the switch, removing the speaker, reaching in and pushing the switch up. Side by side oem and chinese look identical and the replacement works perfect. Just picked up a V6 panamera with the same issue (pass side window as well). Bought the same replacement, this time on amazon. $40 for driver, $10 for pass.
Old Jan 14, 2017 | 09:21 AM
negb's Avatar
...ja, price is twice less, but that's for different door switch, the one like mine is not available in China ....
https://www.aliexpress.com/wholesale...+window+switch
Old Jan 14, 2017 | 09:35 AM
verdugo135's Avatar
You're right. Seems like you have blind spot monitoring.
Old Jan 16, 2017 | 03:39 PM
ddx77's Avatar
ddx77 is infamous around these parts
Removed speaker grille
Just curious how you popped off the speaker grille. I have plastic trim removal tools but
Couldn't seem to get it to pop out. I didn't want to force it. Any advice?
Old Jan 16, 2017 | 04:02 PM
negb's Avatar
about which speaker grille we are talking: Bose or Burmester ?
Old Jan 16, 2017 | 04:20 PM
ddx77's Avatar
My car has the Bose, not sure of the original post. Thanks
Old Jan 17, 2017 | 07:47 AM
verdugo135's Avatar
like i said i tried to remove the whole door panel per a video on YouTube (type in panamera door panel removal). I got to the very end but the door panel wouldnt pop out. Frustrated i played with a few options and realized i could pry off the speaker grill. Mine is bose as well. Only way i can explain it is to get a very thin screwdriver or trim removal tool and start at the very front of the grill. Once you can see how its held in you can pull it off slowly.
Old Jan 19, 2017 | 09:05 PM
Bart4speed's Avatar
You guys need to "tip" your SA all the time if you want them to put this under warranty. Otherwise good luck.
Old Jan 21, 2017 | 11:47 PM
Lboogie78's Avatar
Lboogie78 is infamous around these parts
Funny how that's the same switch that missing on mine as well.
Old Mar 26, 2017 | 05:33 PM
Flat6Motorsports's Avatar
Flat6Motorsports is infamous around these parts
FYI - On a Panamera (Turbo w/ Bose speakers). You can remove the speaker grill, pry the front corner with a small pick or hook and just work it back and forth and slowly pry back. Be careful, a lot of fine leather, so take your time and have patience. The entire speaker comes off. Unplug the harness with your hand inserted into the speaker opening. Then start to push up on the window switch. It has 4 metal clips, not sure an exact strategy here, I just sort of worked it back and forth on each side and it came loose that way.
