Panamera Driver Side Window Switch Issues.
Old Sep 18, 2017 | 09:52 AM
  #46
skiracer13's Avatar
5 Year Member
skiracer13 is infamous around these parts
Great results w/ jayi836's $19 fix
I also purchased this switch kit - delivered for $19 - and replaced all 4 switches in minutes. I'm not quite sure how the PO broke off the originals but hopefully these will last longer under my stewardship.
Here are some before and after pics...
ID:	512827   Click image for larger version
ID:	512828   Click image for larger version
ID:	512829   Click image for larger version
Old Sep 20, 2017 | 02:38 AM
  #47
negb's Avatar
negb is infamous around these parts
what is this ? peel off and gap - doesn't look quality at all !!
Old Sep 20, 2017 | 04:14 PM
  #48
skiracer13's Avatar
5 Year Member
The bottom switches weren't replaced - only the 4 window switches. After seeing the gap in the pic I simply nudged the bottom switch so that it lines up per the pic below. I'm not quite sure what the PO has done to these switches but they seem to have seen some wear for sure.
My car is 8 years old and I know it isn't perfect - for $19 this was the right fix for me. It is a bit of a complicated procedure and it does take almost 2 minutes to complete all four switches, so you may be better off just buying the entire panel from the dealer.
Old Sep 29, 2017 | 11:07 AM
  #49
jayi836's Avatar
jayi836 is infamous around these partsjayi836 is infamous around these parts
Seems like these parts are sourced from all over the world, Turkey if recall.
There may be some lint or debris causing it to be out of alignment combined with some tool marks.
A flat plastic blade works without marring the surrounding plastic.
Bottom line is no one will see this and as you said the car is 8 years old.
Just comes down to the level of effort to replace a $140.00 part not made by Porsche.
We live in an instant gratification time, a 2 minute install is perhaps minute too long :-)
Porsche and Audi are the most profitable divisions of VW.
If you want a perfect car lease every 3 years, keep their share holders happy.
https://www.fool.com/investing/gener...ks-for-vw.aspx
Old Apr 30, 2018 | 07:27 PM
  #50
ciaka's Avatar
I was looking at similar occurrences. Want to replace one chrome trim for one button.
From research, found that YOU DONT HAVE TO PURCHASE ENTIRE SWITCH ASSEMBLY.
You only need porsche panamera button chrome kit.
Kit costs about 20 bucks for 4 buttons. I will look into how these are replaced, but from knowledge collected thus far, each button is removed by pressing in a tab going down side of each button. So I will try to get this done. Will comment after i try. But you dont need entire switch assembly. Only the trim kit. Cheap.
Old Jul 11, 2018 | 09:50 AM
  #51
AL Be's Avatar
Junior Member
AL Be is infamous around these parts
Window Control Switch
Hi,
just came across your post. Is your window switch still available? Would be interested
I'm new to this site. May email me abkm81@gmail.com
looking forward on your reply.
Originally Posted by Just A GTS
Thanks for this tip! Will try to do mine tonight!
Anyone need a non side assist control in great condition? I am putting in the correct one on mine.
Right side of the pic is what I'll be posting for sale. All the chrome tips are intact.
Attachment 481644
Old Jun 2, 2019 | 08:58 AM
  #52
fullmetaljacket's Avatar
fullmetaljacket is infamous around these parts
Purchased a switch assembly from China recently for around $40 and decided to hold off DIY til I find the right instructions how to remove the old switch. Found in this thread that removing only the front door speaker grill would be the safest and fastest way. Thanks for the posts and pix. Here's the finished product. Works perfectly!
So here's the thing, I discovered that if you go through the route of forcing the grill out will make the clips expand causing the grill to have a gap of around 3mm in between the grill and the door. The grill will now rattle everytime you close the door. We dont want that! The only solution is to install either a double adhesive tape or a foam tape measuring 4.5mm to 5mm thickness on the grill frame to keep it snug. Hope this helps.
Old Jun 5, 2019 | 09:14 AM
  #53
AluminumMistress's Avatar
AluminumMistress is infamous around these parts
I actually just did this the other day too because one of the switches broke off at the base of the master switch assembly. Can’t tell it was $30 and works perfectly!
Jul 29, 2019 11:13 AM
rnl
Aug 26, 2015 02:36 PM
tkeck3
Aug 25, 2015 02:52 PM
Zero911
Aug 24, 2015 06:51 PM
pwdrhound
Aug 23, 2015 07:36 PM
