Lifting the Rear of P4S
Old Aug 9, 2015 | 01:34 AM
superscribe's Avatar
superscribe is infamous around these parts
Hello. I've seen a post on insane garage about four primary lift points on the Panamera, and 4 secondary lift points.
http://www.insanegarage.com/lifting-...ngs-need-know/
I see that there are instructions to remove the transverse strut as what seems to be a precaution. Has anybody lifted the Panamera with rear secondary lift points without removing the strut? Has it caused issues?
I ask because if so, I have to remove an underbody lining before I remove the strut before I lift the rear.
Obviously if it's going to bend, break, or plastically strain something, I'll take the extra steps. Thanks all!
Old Aug 10, 2015 | 10:21 AM
okay, cool. so my name is superscribe. I enjoy long walks in the mountains. I purchased a P4S because I like nice things, but I also dig natural aspiration. I get sideways with the Panamera sometimes because it's awesome. I can get 3 other friends in my Panny and still smoke other cars in the corners, which is where I think the real racing happens. The Burmester system is ridiculous, but I'd just really like to make some changes which require the car to be on stands.
It's nice to meet you all, and if you've ever worked on an AWD Panamera, I'd love to dialogue about that damn rear strut.
Old Aug 10, 2015 | 11:59 AM
Goonie's Avatar
Goonie is infamous around these parts
lol
sorry I haven't had mine up in the air yet but when I do my exhaust, I will post up some pics.
Old Aug 20, 2015 | 10:56 AM
Goonie, Thanks a lot. Let me know how that goes, and I appreciate it!
Old Aug 27, 2015 | 08:41 AM
Hawk375's Avatar
Hawk375 is a name known to allHawk375 is a name known to allHawk375 is a name known to allHawk375 is a name known to allHawk375 is a name known to allHawk375 is a name known to all
you only need to remove transverse strut if you intend on using the secondary lift points...which should only be if you need to work on something that the primary lift points would be a part of
and to use the secondary lift points...you'd have to initially lift it with the primary points to be able to remove the transverse strut
Old Aug 30, 2015 | 08:19 PM
Hawk375, I'd need to use the secondary lift points to get a jack onto the primary lift points.... so if i wanted to use the primary lift points I'd have to use the secondary lift points provided I don't have a factory lift.
Old Aug 31, 2015 | 09:28 AM
Hawk375's Avatar
Not sure why you'd have to use the secondary lift points to use the primary lift points. I've lifted at the primary lift points with a standard hydraulic jack without any problems.
Old Aug 31, 2015 | 09:59 AM
I've always been told that it's not good to have the car resting on a hydraulic jack for long periods of time. As a result. If I lift it with race jack, then I want rest the car on jack stands, I don't see how I'd do that with out using a primary and secondary. Sounds like you're saying the transverse strut's gotta come off?
Old Aug 31, 2015 | 10:51 AM
Hawk375's Avatar
the strut itself isn't meant to be load bearing, it can bend or break under the weight of the car...you'll have to remove it before you use the mounting points as a lift point.
Jul 29, 2019 11:13 AM
Steven997TT
Aug 27, 2015 02:56 PM
mep1811
Cayenne 958
Aug 27, 2015 02:24 PM
gulf gt
Aug 27, 2015 10:27 AM
rnl
Aug 26, 2015 02:36 PM
