Methanol Kit Installation Complete!!!
Old Mar 29, 2017 | 01:43 PM
RxPorsche's Avatar
RxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud ofRxPorsche has much to be proud of
Thumbs up Methanol Kit Installation Complete!!!
Hi all here some pics, car feels strong....
Old Mar 29, 2017 | 02:22 PM
Just A GTS's Avatar
Just A GTS has a spectacular aura aboutJust A GTS has a spectacular aura aboutJust A GTS has a spectacular aura about
That's a lot of work. Looking good sir!
Old Mar 30, 2017 | 10:23 AM
RxPorsche's Avatar
Thumbs up
Thanks buddy!!!
Old Mar 31, 2017 | 01:25 PM
Glareice's Avatar
Glareice is infamous around these parts
looks great, what did the kit cost, which kit di you use and number of hours invested. Thanks!
Old Mar 31, 2017 | 06:32 PM
RxPorsche's Avatar
Thumbs up
The kit cost like $550, http://www.snowperformance.net/Gas-w...kits-s/100.htm.
The mechanic charge for 10 hours, he did a very excellent job.
Old Apr 1, 2017 | 09:20 PM
Chedman13's Avatar
Chedman13 is infamous around these parts
What's the mix ratio?
Old Apr 2, 2017 | 05:06 AM
RxPorsche's Avatar
I'm using 60% methanol and 40 % water.
Old Apr 3, 2017 | 12:02 PM
tfuhst96's Avatar
tfuhst96 is infamous around these parts
That's a clean setup. Is it just ran through a throttle body spacer?
Old Apr 4, 2017 | 09:59 AM
Lboogie78's Avatar
Lboogie78 is infamous around these parts
Wonders if going custom E85 setup would benefit even more better??..
Old Apr 4, 2017 | 10:13 AM
RxPorsche's Avatar
No throttle body spacer.
Old Apr 4, 2017 | 10:21 AM
RxPorsche's Avatar
I'M sure E85 will benefit a lot more but you will also need injectors, fuel pump and a special map. That will take a lot of money.
Old Apr 5, 2017 | 07:57 AM
tfuhst96's Avatar
What exactly is it connected to then?
Old Apr 5, 2017 | 09:40 AM
RxPorsche's Avatar
Directly to the throttle body, no spacer.
Old Apr 9, 2017 | 09:10 AM
tfuhst96's Avatar
Did you get a tune to run this setup?
Old Apr 10, 2017 | 02:08 PM
RxPorsche's Avatar
Hi, the car have FVD tune this is the info they have on their site.
ADAPTABLE – Our software is adaptive and as such we give you hundreds of software timing maps. That’s right, hundreds of software maps! No need to contact us for other “Custom” time consuming “OTS” off the shelf calibrations, flash once with FVD Software and be done. Each of our maps are tied into the vehicle’s sensor information so with differing variations in climate, throttle, altitude, exhaust gas temperature and octane our software automatically adjusts to give you superior performance and a factory-smooth feel. We also adjust the software to accommodate 91-100 North American ((RON+MON)/2) and Rest of World 95-104 (RON) octane automatically (adjusts timing and knock sensors accordingly). This is done automatically without the need of external hardware or toggling through the cruise control functions, just fill and go! If you want to change the intake or add a throttle body in the future, for example, our software will also adapt for larger Porsche® throttle bodies and IPD plenums with greater air mass automatically, simply install and feel the gains without the hassle of sending the ECU back or having to install another file.
