Front end noise and clunks
Old Oct 10, 2017 | 12:09 PM
poundsan's Avatar
poundsan is infamous around these parts
Hi There,
I had the noise issue for almost a year and I just found out on insane garage website.
From what I have learnt, i have to replace
1.Upper control arms (both sides)
2.Lower control arms (both sides)
3.Front Sway bar bushings
4.Front sway bar end links
I live in Myanmar where we don't have porsche dealership so I want to know the exact part number for those items i have to order. I don't want to make mistake while ordering so Can you guys help me?
My car is porsche panamera turbo 2011 with pdcc
also i have another question,do i have to replace the whole control arm or bushings only.
thank you so much for your time
kyle
Old Oct 10, 2017 | 09:18 PM
amgpan's Avatar
amgpan is infamous around these parts
Mine is a 2010 Turbo with PDDC.
Pretty much all these parts are available at suncoast
970-341-243-01
Lower Control Arm Outer Bushing
970-341-241-01
Lower Control Arm Bushing
970-343-793-07
Stabilizer Bar Lower Mount
970-343-792-07
Stabilizer Bar Upper Mount
970-343-069-21
Stabilizer Link
970-341-051-03
ARM BUSHING FRONT UPPER ARM
970-341-245-02
Control Arm Bushing
I recently did all the above in my car, and it totally eliminated ALL creaking & knocking noises.
Also make sure when they are under there to tighten ALL subframe mounts. SOME of mine were loose also.
Non only did it eliminate all the creaking, the car steering feel so much more DIRECT now.
Old Oct 10, 2017 | 10:25 PM
poundsan's Avatar
It is amazing you only had to change the bushing not the whole arm. It costs a fortune to change the whole arm.
Thank you so much mr.amgpan
Old Oct 10, 2017 | 11:19 PM
jrjunior31's Avatar
jrjunior31 is infamous around these parts
Anyone have these issues on a '15? Wondering at what mileage I may start to notice problems. I have a '15 PGTS. Thx for any info.
Old Oct 12, 2017 | 03:42 AM
amgpan's Avatar
I think all these problems were rectified in the 2014 update.
Old Oct 16, 2017 | 05:26 PM
negb's Avatar
negb is infamous around these parts
Depends on joint on the arm, if that one is weak and you don't know who could refurbish it for you then you need the whole arm.
for upper arms I would strongly recommend these bushings:
http://siberianbushing.com/part/22-06-1711
And have a look into these threads:
https://www.6speedonline.com/forums/...-replaced.html
https://www.6speedonline.com/forums/...sion-help.html
Old Jun 1, 2018 | 07:50 AM
CLKFAN's Avatar
CLKFAN is infamous around these parts
Are you 100% sure these poly bushings work for the upper arms? Have you tried them and you speak from experience?
Old Jun 1, 2018 | 09:33 AM
negb's Avatar
Yes I have them installed in my Panny now as custom made blue ones were squeaking in these upper arms and I decided do not make new ones and try these 'siberian' type.
