Panamera 4S 4.8 engine ping
Old Nov 1, 2017 | 10:02 AM
tzeseong's Avatar
tzeseong is infamous around these parts
Hi all,
as per my thread subject. does any of the P4S 4.8 have engine ping issue?
it happen to my car on low rpm. For an example- constant speed, constant throttle, if the road grade changes uphill slightly and I try to maintain the speed it will start to ping.
The moment I downshift the ping would go away.
any owners is having this same issue?
any pointers to look into this problem?
Old Nov 1, 2017 | 04:38 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
what kind of fuel you using?
Old Nov 1, 2017 | 05:17 PM
riden's Avatar
riden has a spectacular aura aboutriden has a spectacular aura aboutriden has a spectacular aura about
I believe Porsche specified a mini octane rating of 90 (US rating system). Try adding some octane booster to the tank.
Old Nov 1, 2017 | 06:37 PM
tzeseong's Avatar
Im using RON100
Old Nov 1, 2017 | 06:38 PM
tzeseong's Avatar
Im using RON100. back in my country we have RON100
Old Nov 1, 2017 | 07:01 PM
riden's Avatar
A 90 AKI is equivalent to 95 RON according to my owner’s manual so assuming the fuel is good quality. Octane requirement is covered.
Old Nov 1, 2017 | 08:15 PM
tzeseong's Avatar
Yup...octane requirement should be covered.
tzeseong's Avatar
anyone facing the same issue on Panamera 4s 4.8?
Old Nov 2, 2017 | 05:35 AM
cerbomark's Avatar
Next would be carbon buildup. How many miles on car? Higher miles cars with these DI engines can build up carbon causing pinging.
Old Sep 22, 2025 | 05:01 PM
Djotta's Avatar
Djotta
Hey all, resurrecting this thread, I have the exact same problem with my Panamera 4S, it's more noticeable when the weather/engine is hot and going slightly uphill.
The ping is greater when the PDK upshifts even in sport mode. I changed the coils and spark plugs, it helped a bit but it didn't solve the problem entirely.
When doing this service, the mechanic checked and noticed carbon buildup deposits at cylinder 1 so by looking at the last post that could be the problem.
The car has 140000 miles.
I'm wondering why there is no check engine in this case since the noise is really audible and no fault codes
