What to Replace with Thermostat?
Old Feb 15, 2018 | 01:23 PM
fulwild's Avatar
fulwild is infamous around these parts
New owner of 2010 PTT. (49K Miles) Check engine light (CEL), (yellow warning) x2 days
Scan showed multiple, mostly low voltage, faults(25 total in 10 areas). Battery was original with March 2010 build. Battery was recently recharged as maintenance after purchase using CTech 7002
Among the faults was:
P0597 Thermostat driver Which is diagnostic for either a bad sensor connection or faulty thermostat
After replacement of battery with Duralast Platinum AGM (AutoZone H8-AGM), the CEL returned and scan returned 2 fault codes. P0597again and
U0422 Ambient Temperature via CAN 1) Gateway control module incorrect or 2) Message via CAN defective or missing
All engine\seems to blast hot air on auto. (50F outside) so not much heater action.
Proposed courses of action Replace thermostat (948 106 034 01)
Questions:
Should I replace the water pump (948 016 033 01) as its off anyway to get to the thermostat?
I have seen mention of cracked/problematic thermostat housings if housing is original plastic? (948 106 080 01 ?) I'm assuming I should replace with (948 106 080 02) (aluminum?) is this proper or overkill?
Any other hard parts should replace while I'm in the area? Plastic radiator drain plug? (is this a thing? part#?)
Parts list:
948 106 034 01 Thermostat and Gasket set (PK970V6THERMO)
948 106 707 00 Thermostat o-rings included in above
948 106 533 00 Water pump gasket included with above and below
948 106 033 01 Water pump with gasket
948 106 080 02 Thermostat Housing
948 106 124 02 Gasket for thermostat housing
970 106 215 00 Drain plugs x2
Thanks for any help
Old Feb 25, 2018 | 05:46 AM
negb's Avatar
negb is infamous around these parts
Originally Posted by fulwild
Questions:
I would go for new pump, extra few hundreds won't harm, proper water pump p/n 94810603301
original thermostat housing (p/n 94810608000) is no longer use, you will get p/n 94810608002 for another +-200$
part no.2 on this diagram ? p/n 97010621500
Old Mar 9, 2021 | 12:30 PM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
the issue with the housing was the pipes are glued in and the glue fails, allowing for a rapid coolant dump, you can either replace it or pin the pipes in.
Argus
Sep 19, 2018 10:59 AM
omegarex
Jan 5, 2017 06:06 PM
thethor
Jun 20, 2015 09:24 AM
cab83_750
Sep 7, 2013 09:18 PM
Mad Ness
Jul 23, 2010 12:43 PM
