Panamera turbo fluids questions
Old Apr 21, 2018 | 10:41 PM
ciaka's Avatar
Can someone fill me in on fluids please?
My questions are related to 2011 Pan turbo
1. What grade of oil do majority use (exactly what oem manual says or slightly different like cayenne for example)
2. What make of oil is best to use?
3. is trannie fluid sealed, and if so, how often is it replaced in miles?
4. Anyone done analysis on their panamera tran fluid? what make fluid is used, and are there alternatives to dealer make?
5. Same question about other major fluids in the car
Trying to get details early on, as I plan fluids change asap, check plugs/coils, brakes appear good.
Thank you.
Old Apr 22, 2018 | 02:34 PM
dudecs's Avatar
dudecs is a jewel in the roughdudecs is a jewel in the roughdudecs is a jewel in the rough
1. Mobil 1 0W-40 (synthetic) is the Porsche recommended oil.
2. Search for "Porsche approved oil".
3. PDK fluid change is a 60K mile service.
4. PDK fluid equivalent is Pentosin FFL-3, requires 6qts (?).
5. 2011 recommended service schedule here.
Old Apr 22, 2018 | 06:46 PM
ciaka's Avatar
Geat. Thanks.
Anyoe run 5W40 castrol syntec? Bit thicker cold.
CTT folks many switched to that, better.
Old Apr 22, 2018 | 07:03 PM
Victory007's Avatar
Victory007 is infamous around these parts
Timely info. I was just about to begin research on changing the Tranny fluid. Question - Is 6qts what you actually wound up using or a estimate. I see most Transmission Change kits for our cars come with 9l (about 9.5 quarts).
https://www.blauparts.com/porsche-pa...hange-kit.html
Old Apr 22, 2018 | 09:02 PM
ciaka's Avatar
It would be good to know what the procedure for doing transmission fluid changes for Panamera. On a Cayenne you have to refill transmission fluid at specific temperature, so I assume on the Panamera it will be the same. It would be great for anyone to post up procedure for a transmission fluid change so we can all benefit. Thank you.
Regarding the amount of fluid, I would bet you have to empty it out then start the car around it for a short time to make sure more of it comes out as you shift the gears, to maximize drainage. After that you would be able to refill it with the specific amount listed. Again it will be great to know the actual process as listed in the service manual.
Old Apr 23, 2018 | 06:04 AM
Small Car Lover's Avatar
Small Car Lover is infamous around these parts
Check out this link and the subsequent pages by clicking next page on the upper right of the page.
https://workshop-manuals.com/porsche.../changing_atf/
Old Apr 23, 2018 | 11:36 AM
ciaka's Avatar
Awesome. Thanks. Looks like the process is same as Cayenne. Measure fill qty at 40C, shifting between gears few times to ensure right fluid level. Once fluid starts spilling out, it is proper fill.
It is a messy process, so anyone doing, cover the floor under to catch fluid.
Old Apr 23, 2018 | 06:36 PM
negb's Avatar
negb is infamous around these parts
Geat. Thanks.
? why better, less oil consumption ?
Old Apr 23, 2018 | 07:57 PM
negb's Avatar
some not only fluids list what I did for my 970 Turbo S
Last two items only OEM availible
0W-40 Exxon Mobil 1 or Valvoline SynPower or any meeting Porsche A40 standard
Mahle OX 254 D4 oil filter element WITH sealing ring
75W-90 LIQUI MOLY GL5 synthetic rear differential fluid
Motul RBF 660 brake fluid
Bosch FR6 NPP spark plugs
Mahle LAK 120 ACC cabin particulate filter
MANN C69226 air filter element
PDK oil Pentosin FFL 3
97032102500 - PDK Transmission Oil Pan with filter & drain plug
97035907101 - PDCC Reservoir
Old Apr 23, 2018 | 08:12 PM
ciaka's Avatar
Someone on cayenne forum actually did chemical analysis st new and after intervals of use, snd found the castrol syntec edge suspended particles better and lasted longer. Its been few years since I dug into this, but remembered it.
Thanks very much for the list of fluids, parts. Will come useful very soon.
Old Apr 23, 2018 | 08:37 PM
negb's Avatar
OK, understood, this was about brands,
I thought that about viscosity 0W-40 vs 5W-40
Old Apr 24, 2018 | 07:15 AM
amgpan's Avatar
amgpan is infamous around these parts
I personally run 5W50 Mobil 1.
Porsche approved.
And since running it, the car consumes LESS oil between oil changes.
Old Apr 26, 2018 | 11:59 AM
ciaka's Avatar
I will start with 5W40. Will run Castrol Edge Synthetic.
Used it on Cayenne turbo without any issues and should be perfect for this car too. Has the Porsche A40 certification.
We will see what happens after few months.
boca996tt
May 3, 2008 02:31 PM
Brucem
Apr 20, 2006 07:31 AM
VoltesV
Feb 2, 2006 05:26 PM
gregy
Jan 24, 2004 11:40 AM
