DIY - Gas Cap Replacement
Old May 14, 2018 | 02:57 PM
ciaka's Avatar
If at any time you get errors related to EVAP (small leaks, etc), chances are your gas cap is not holding pressure in the tank.
This is one of most common ways to fail inspections. Then they sell you a gas cap at twice the price, charge you for half hour or an hour of time, and you end up paying $250 or more to get it done.
Who on here finds this a familiar situation? Don't raise your hands (I wont see anyways...lol).
Well, you can get this done in about 5 minutes, if you include a break (should you get tired during the install).
Hope this helps others in their quest to be a DYI master on Panameras.
Old Dec 4, 2022 | 11:39 AM
cbwinters01's Avatar
cbwinters01 is infamous around these parts
Thanks Ciaka. Getting cel,codes p0456 (tank system micro leak) and p0442 (fuel tank ventilation system - fine leak detected), seem to have started after taking the gas cap off. hoping that the issue is just as simple as replacing the gas cap on my '16 pseh.
BruceR
Bentley
27
Sep 11, 2023 11:23 AM
Mazurda
Dec 27, 2019 11:56 AM
cadman
Sep 9, 2017 10:09 AM
HabitualOffender
May 13, 2017 10:53 AM
John Romano
Dec 10, 2009 05:34 PM
