What size tires is everyone running
On my 2010 I'm running the following,
255/40R20 Front
295/35R20 Rear
Falken Azenis FK510
So far been pretty good, treadwear and grip have been great. Had them put on the end of May. Ran over something and cut one pretty bad (rear) but was covered under warranty so it was replaced for free.
255/40R20 Front
295/35R20 Rear
Falken Azenis FK510
I was trying to get a set of Mich Pilots 275/40/20 and 315/35/20 but it was on back order and I didn't want to wait several weeks for them. I ended up running Summer P Zero 255/40/20 F and 295/35/20 R surprisingly these tires grip like hell and not even loud at all.
What about this configuration below? That would protect the turbo rims and be more stable with wider tires.
MICHELIN
PILOT SPORT ALL SEASON 4Ultra High Performance All-Season
MICHELIN
- Front: 275/40ZR20 106Y XL
- Style: Blackwall
- Eco Focus: Michelin Total Performance
- Load Range: XL
- Serv. Desc: 106Y
- UTQG: 540 AA A
- Mile. War.: 45,000 Miles
- Qty:
Per Tire:
$317.99- 1 In Stock
- Additional inventory due 12/30/22
- Delivery by Monday, 01/09to 94040
- Free Shipping
- Rear: 305/35ZR20 107Y XL
- Style: Blackwall
- Load Range: XL
- Serv. Desc: 107Y
- UTQG: 540 AA A
- Qty:
Per Tire:
Thank you for your feedback. Yes, they are in stock 275 and 315. I currently have 15mm spacer all around with the original tires. if I go with 275x40x20 front and 315x35x20, I don't need 15mm spacer anymore. Am I right?
Many thanks.
Many thanks.
My experience with my 996 turbo tells me that the most important thing to keep the same is the difference in Rotations Per Mile front/back. This is because the center diff’s viscous coupling needs the factory difference or it “thinks” there is slipping and gets engaged. this build heat and wears out the diff over time. Just keep that in mind.
