Porsche panamera oil Leak from top of engine
Old Aug 11, 2018 | 02:44 PM
Porschepan's Avatar
Porschepan is infamous around these parts
Originally Posted by DogWood
yes it would - bad separator would create a higher vacuum in the crankcase
ased on my pictures do you see anywhere else oil can be spitting out from in that area?? It has to be from top because the bottom of my car and garage is bone dry no oil leaks at all from the bottom
Old Aug 11, 2018 | 05:30 PM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
if it isn't puddling up on the pan, then it's getting burned
Old Aug 11, 2018 | 08:02 PM
newporsche's Avatar
5 Year Member
newporsche is infamous around these parts
how fast was your oil consumption to the minimum level?
Old Aug 11, 2018 | 09:42 PM
DogWood's Avatar
5 Year Member
I've only had my car for about a month, and it hasn't moved from the full.
Old Aug 16, 2018 | 05:59 PM
skiracer13's Avatar
5 Year Member
skiracer13 is infamous around these parts
Are you monitoring oil consumption regularly? My friend has a 4S and he burns thru a quart every 700 miles and his SA claims it's normal for that engine. My PTT usually goes ~2,500 miles before the oil level monitor drops a single bar so it seems to vary widely depending on the model. If you don't have any leaks on your garage floor it could be simple operating consumption that's considered to be normal.
I haven't heard about too many AOS failures on the Panamera, but as a previous 996 owner it was a common failure item and not terribly expensive of a fix IIRC. Did you mention how many miles on the car? Good luck!
Old Aug 17, 2018 | 04:41 AM
Porschepan's Avatar
i have 47,500 miles on it now its been about 1k miles since my oil change.. i filled it with a quart few days ago it hasnt dropped any levels of oil and i havent seen anything leaky on top of the engine so im just watching it closely as of right now
Old Aug 24, 2018 | 11:57 AM
ciaka's Avatar
You will notice that the turbo versions of the car will go through most oil due to the - you guessed it, the turbos.
Amount varies, but if you stay reasonably within manual details, no need to worry. My PTT eats about a glass/250cc/1 square on display, every 1000 miles or so.
Old Aug 25, 2018 | 05:52 AM
HP41's Avatar
HP41 is a jewel in the roughHP41 is a jewel in the roughHP41 is a jewel in the rough
Another data point:
My 2014 4S. (3.0 L V-6 bi-turbo). uses .25 quart in 7,500 miles. (one bar on the display) in mostly freeway driving.
Dale D
Cayenne 955/957
19
Aug 12, 2018 06:45 AM
newporsche
Jun 29, 2018 03:46 PM
BallinGPM
Sep 27, 2009 01:24 PM
bond
Jan 31, 2006 11:07 AM
