Porsche panamera oil Leak from top of engine
Old Aug 9, 2018 | 01:47 PM
Porschepan's Avatar
Porschepan is infamous around these parts
Have a 2012 panamera S v8 and i havent got a check engine light or anything but im losing my oil its leaking from the top as shown in pictures .. anyone have any idea whats the cause of this also why isnt there a check engine light on ?? Please let me know i have added pictures of whats happening ..
Old Aug 9, 2018 | 06:12 PM
Porschepan's Avatar
Anyone have any idea??
Old Aug 9, 2018 | 06:40 PM
ace10's Avatar
ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !ace10 Is a GOD !
Why do you think it is engine motor oil?
Old Aug 9, 2018 | 07:16 PM
Porschepan's Avatar
Hey ace check out this pic of the oil level from the dash guage , min reach so its for sure engine oil im just wondering why not atleast an check engine light or some warning i guess
Old Aug 9, 2018 | 07:29 PM
dudecs's Avatar
dudecs is a jewel in the roughdudecs is a jewel in the roughdudecs is a jewel in the rough
Looks like the air-oil separator failed?
Old Aug 9, 2018 | 08:07 PM
Porschepan's Avatar
yes im thinking the same , any reasons why that fails is that something common or what as i dont see any other panamera owners post that they had similar problems .. im going to look into it this weekend since ill have the time just wanted to post here and see what others might think it is , also should i get a check engine light or an oil low light soon when the oil drops even more?
Old Aug 9, 2018 | 11:46 PM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
all parts fail eventually, doesn't seem to be a major failure point, but it is common enough. Are you seeing white smoke? (oil being burned)
Old Aug 9, 2018 | 11:52 PM
ciaka's Avatar
when oil is at min, the pic shows dip stick oil at lowest notch and oil is yellow. It can drop more below min. Then you will get same pic, but oil will not be displayed on dipstick, and area below stick will be red.
Add oil now before you get that low.
yes, looks like your oil separator not functioning, may need replacing. Appears easy to do. Unless oil coming from other place. You would have to verify. Take care.
Old Aug 10, 2018 | 04:45 AM
Porschepan's Avatar
no white smoke seen also no rough idling just the oil leaking out at that top part no oil reaching the floor i check my garage over night nothing only in the engine bay near the oil seperator . But now i cant see the oil level says not available
Old Aug 10, 2018 | 04:47 AM
Porschepan's Avatar
ok, so how much oil do you thing i should get since i reached min, ill grab oil & replace the seperator by the way if the oil drops more to the red mark will it give a oil light on dash ? Or check engine or no
Old Aug 10, 2018 | 06:08 AM
dudecs's Avatar
After you open the engine hood, the oil level cannot be read until after being driven for about 10 miles. If the oil was at minimum already, it requires 1 quart to bring it back to full. You don't want the oil level to go any lower and watch the oil pressure. Minimize driving the car until you replaced the part.
Old Aug 10, 2018 | 08:19 AM
DogWood's Avatar
5 Year Member
I would top it off and then have the oil separator checked out, when was the last time you checked the oil level? (before it got this low)
A simple check would be to try and take the oil fill cap off while it's running - a failed separator generally causes too much vacuum in the crank case, oil cap will be harder to remove if that is the case.
Old Aug 11, 2018 | 02:11 PM
Porschepan's Avatar
ok, ill try to test it like that so while car running try taking off oil cap, if its harder to take off than taking it off while car is off that would mean seperator is bad??
Old Aug 11, 2018 | 02:12 PM
Porschepan's Avatar
Based on my pictures do you people see anywhere else oil can be spitting out from in that area?? It has to be from top because the bottom of my car and garage is bone dry no oil leaks at all from the bottom
Old Aug 11, 2018 | 02:31 PM
DogWood's Avatar
5 Year Member
yes it would - bad separator would create a higher vacuum in the crankcase
