Coils, plugs questions
Old May 24, 2019 | 08:09 AM
Paul Rathjen's Avatar
Paul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond reputePaul Rathjen has a reputation beyond repute
If the plugs are ok, and fairly new, there is no reason to replace them. When I changed my plugs, I bought 3 coils just in case. I ended up not installing any of them because all the factory ones were fine. 39,000 miles. I do use a lot of oil, fuel additives and valve cleaner spray regularly - maybe its snake oil, maybe its not!
Old May 24, 2019 | 11:04 AM
ciaka's Avatar
Panamera is directly injected, which means fuel is injected into the cylinder below valves. In non DI cars, fuel is injected into cylinders from above valves, which causes the valves to be cleaned and washed by the fuel itself. Then, additives did help to keep them clean and clear. In DI case, the washing is not happening, so the valves end up gunking up over time, necessitating walnut cleaning scenario. I do not know what dictates how quick the gunk accumulates or not.
barncobob
Jul 13, 2015 10:27 AM
Boatsonthebrain
Mar 9, 2011 01:24 PM
EB_1920
Cayenne 955/957
Nov 8, 2010 03:13 PM
GTstreet996
Aug 25, 2009 09:01 PM
ypshan
Jun 2, 2005 08:18 AM
