Air suspension failure
Old Sep 17, 2018 | 11:22 AM
Bobby Buggs's Avatar
Bobby Buggs is infamous around these parts
Red face Air suspension failure
Went to get in my car this am after a quick breakfast and thought it looked a bit low in the front.
Driving and this came up
I tried to raise it while I was calling roadside assist and got this
Dealer told me not to drive like this. I get out of the car and I hear the compressor run and the car rose to proper hight. In less than 2 minutes I hear a leaking sound and down she went.
She is CPO but I just had the new exhaust installed and hope that shop didnt fudge anything up while they were installing it. I kinda doubt they were anywhere near that area but weird it happened shortly after that visit.
Air shock failure???
Old Sep 17, 2018 | 11:26 AM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
is it low on both sides or just one?
Old Sep 17, 2018 | 12:07 PM
Looks like driver side only and thats where I could hear air leaking from, on second thought I cant really say
Old Sep 17, 2018 | 12:09 PM
tallpaul's Avatar
tallpaul is infamous around these parts
Single side as DogWood asked? If the leaking sound is coming from the strut (specifically the top) you may have just popped a bag. While you can normally drive when it's low and then fills up, if its leaking that quickly it's probably dead.
It is possible they snagged a line during the install and pulled out, but I think the value of the strut wouldn't let that happen. In that case, its more likely to never fill or leak when raising/lowering, not often. My gut is the bag ripped. Hit any holes recently?
I've had leaks in several struts, but never when it will leak within 2 minutes.
Old Sep 17, 2018 | 12:20 PM
Well she is at the dealer by now, we will see in a couple days
Old Sep 17, 2018 | 12:51 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Sorry to see this again. These systems (in all makes not just Porsche) almost seem to be a serviceable item that eventually all will undergo repairs.
Old Sep 17, 2018 | 02:26 PM
They said the left side bag is cracked at the top and the right one looks crappy so both are getting replaced under CPO, approx $9000. Have to say Im impressed with the service so far.
Old Sep 17, 2018 | 02:51 PM
DogWood's Avatar
5 Year Member
wow, that is cool.
Old Sep 17, 2018 | 08:04 PM
newporsche's Avatar
5 Year Member
newporsche is infamous around these parts
9000 for the two bags?
Old Sep 17, 2018 | 08:41 PM
DogWood's Avatar
5 Year Member
they'll be replacing both front struts, Genuine Porsche parts at Pelican go for $1647 ea and you know the dealer is marking up more than that.
Then there is labor at some obscene rate..
so $9k sounds about right
Old Sep 18, 2018 | 06:54 AM
If I get a total I will post the amount
Old Sep 19, 2018 | 09:13 PM
ciaka's Avatar
Go read my aur suspension info th hread. I still have to put up the DIY for air shock, valve body replacements. Looks like you are handling ok.
therron4ou
Bentley
62
Mar 13, 2023 09:35 PM
panamera_lou
May 19, 2018 05:01 PM
MoOriginal
Apr 3, 2018 04:16 PM
GT3Scott
Cayenne 955/957
Aug 10, 2003 11:56 AM
