Porsche panamera coolant leak hose or radiator?
Old 11-29-2018, 04:12 PM
panamera_lou's Avatar
panamera_lou is an unknown quantity at this point
my 2012 panamera has a coolant leak , im assuming its a pinhole or something in one of the hoses or the radiator here are pics. If any of you have an idea where its coming from feel free to comment i havent really got into it but im going to go over it on the weekend heres a pic of what its been leaking over night parked
Old 11-30-2018, 07:56 AM
ciaka's Avatar
impossible to tell just from pic, look at the rad drain plug, sometimes they start leaking if old or not turned off all the way. Its the screws you turn to drain your rad when doing work on it.
Old 11-30-2018, 12:45 PM
I took a picture from the bottom its leaking down from a hose
Old 11-30-2018, 01:07 PM
tallpaul's Avatar
tallpaul is on a distinguished road
I'm going to guess it's an old hose cracked under the clamp at the connector. Hopefully that is all it is. If it's just a hose, relatively easy fix, but you'll need to drain the radiator first to avoid making a huge mess.
Old 11-30-2018, 02:03 PM
skiracer13's Avatar
skiracer13 is on a distinguished road
Are you sure that's not an overflow tube? Have you checked fluid level to make sure it's w/in the limits?
Old 11-30-2018, 05:33 PM
actually not sure what hose is that going to check on it during the weekend now that i have time & do any of you know the process to bleed the system if i drain the radiator and refill with antifreeze?
Old 11-30-2018, 11:56 PM
ciaka's Avatar
Best to have the rad fill tool so you dont end up with air in cooling system.
vman932
05-04-2018 07:17 PM
Kiddkynetik
03-26-2018 12:16 PM
ssj4
04-12-2014 12:12 PM
Yves
07-07-2011 07:35 AM
Quick Reply: Porsche panamera coolant leak hose or radiator?
