2010 front axle
Old Jan 13, 2019 | 09:41 AM
tony102385's Avatar
tony102385 is infamous around these parts
2010 front axle
I need to replace my front axles and for some reason I can only find aftermarket GNK ones for 11-16, will those work on a 2010? I find it hard to believe Porsche would change the design after just one year of releasing the car.
Old Jan 13, 2019 | 10:38 AM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
looking at a pdf of the parts catalog it looks like they have different part numbers for -10, 11-13, 14-16 (970 349 038 02, 970 349 038 03, 970 349 038 04) and oddly enough they don't distinguish front from rear.
no idea what changed.
did find this https://www.sunsetporscheparts.com/o...y-97034903805/
looks like they updated the part
Old Jan 13, 2019 | 01:58 PM
ciaka's Avatar
Porsche Panamera front drive shaft info from my FSM:
As soon as you look at yours, you will know which one you have. Early one is round, the other is not, at the junction to final drive.
2010:
Front shaft: 970 349 038 02
Pan head screw: 900 067 424 01 (expanding bolts, recommend replacement with new ones each time they are removed)
Plate: 1K0 407 357 B
2011-2013:
Front shaft: 970 349 038 03(expanding bolts, recommend replacement with new ones each time they are removed)
Pan head screw: N 910 059 03
nitrorocket
Jul 3, 2016 09:18 PM
MalcolmV8
May 6, 2016 08:00 PM
Trundle997
Nov 23, 2009 11:23 AM
JonnyTTSB
Feb 9, 2008 06:52 PM
