Interior LED swap problem
Old Jan 28, 2019 | 09:22 AM
DogWood's Avatar
5 Year Member
DogWood is infamous around these partsDogWood is infamous around these parts
I suspect that a bean counter got involved, decided they could save $0.25 per car if they made the changes......
Old Jan 28, 2019 | 09:27 PM
LouDA's Avatar
LouDA is infamous around these parts
Wonder how easy it is to retrofit? I too don't have a hood light but would like one!
Old Jan 28, 2019 | 09:30 PM
DogWood's Avatar
5 Year Member
Wiring would be the trickiest part - if that's there I think it should almost be a drop in
Old Jan 29, 2019 | 07:55 AM
970gts's Avatar
5 Year Member
970gts is infamous around these parts
Thinking of retrofitting an under hood light as well. But instead of the OEM assembly, I was thinking about using some surface mount LED's like these from Oznium https <://www.oznium.com/led-bolts-prewired-leds/prewired-surface-mount-led>
That way I can place them where I think they're most useful.
Used Oznium products before and they are high quality, USA and excellent customer support.
The wiring seems to be their already, so it's just a matter of splicing into it.
Wondering what kind of sensor activates it (pin, mercury, ??), and if there's any warranty issues with retrofitting (I'm still under CPO warranty).
Old Jan 29, 2019 | 09:20 AM
DogWood's Avatar
5 Year Member
Found a parts list : https://store.paramountauto.com/auto...omponents-scat
don't see anything that says "switch" though, I would assume it would a simple contact switch perhaps in the latching mechanism, currently at work so I can't look at my car.
Old Jan 31, 2019 | 09:39 PM
Kayvan1347's Avatar
5 Year Member
Kayvan1347 is infamous around these parts
Hi
i was going to change my interior bulbs with LED too. I do have a problem with removing the Dome light. I think there are two metal bracket on front of the Dome that stuck and I can not take it down.
Any suggestions? Is that happened to any one else?
Old Jan 31, 2019 | 10:02 PM
DogWood's Avatar
5 Year Member
there are 4 metal brackets on the dome and they are a pain - I mutilated the hell out of one of mine, so the dome is now only held in place by 3 brackets.
if you have a panel tool, you might try sticking it in up there and see if you can't get them to loosen their death grip
Old Jan 31, 2019 | 10:06 PM
DogWood's Avatar
5 Year Member
there is a switch on the hood latch - I will bet it is for the under hood light
Old Jan 31, 2019 | 10:32 PM
Kayvan1347's Avatar
5 Year Member
I am really worried now. My dome is hanging like half inch now . It won’t click up and doesn’t come down too. I think at least the two from bracket stuck. I don’t know about the side ones.
Did your bracket break? I am scared now to brake multiple bracket and nothing remains to the dome any more.
any input?
Old Jan 31, 2019 | 10:35 PM
DogWood's Avatar
5 Year Member
My best suggestion would be to get a good flashlight and look around up in there and see if you can pin point where it is hanging up, not easy I know, but the only real alternative is to force it down, at which point you'll probably need to replace the brackets.
Old Jan 31, 2019 | 10:45 PM
Kayvan1347's Avatar
5 Year Member
Then in your case just metal bracket broke. Then the dome frame won’t break hopefully . Is that right?
In this case I hope they set the metal brakes.
Old Jan 31, 2019 | 10:48 PM
Kayvan1347's Avatar
5 Year Member
I start with the dome and I am stuck. I am afraid to start changing the other interior light now.
is there any other problems may happen with other lights or they are kind of straight forward?
Old Jan 31, 2019 | 11:02 PM
DogWood's Avatar
5 Year Member
All the other lights are fairly straight forward, the dome is the only tricky one.
DOn't think the bracket broke as much as just got mangled in my case.
Old Jan 31, 2019 | 11:19 PM
Kayvan1347's Avatar
5 Year Member
Wish me luck
thanks
Old Feb 2, 2019 | 08:21 PM
LGARCIA's Avatar
5 Year Member
LGARCIA is infamous around these parts
I ordered a few of the Oxnium LED strips in blue. I’ll install under the dash and in each door pocket
